ProCharger/Vortech Dyno Numbers?
Old Sep 12, 2007 | 01:38 PM
Vette Mag's Avatar
Vette Mag
Cruising
Default ProCharger/Vortech Dyno Numbers?
Does anyone have documented dyno results for a ProCharger and/or Vortech supercharger system on a stock or lightly modified LT1 C4?
We're considering adding one or the other to our '96 project car, but I'd like to hear some real-world feedback first.
Thanks,
Jay @ VETTE magazine
Old Sep 13, 2007 | 12:58 AM
force fed's Avatar
force fed
Like Nike "Just Do It" Either is a huge imprvement!
Old Sep 13, 2007 | 09:51 AM
RVY's Avatar
RVY
Back in 95/96 my Vortech S trim kicked out 405 rwh on the stock engine. This was with a Hypertech chip and the Lucas injectors furnished with the kit. Probably could have done better but didn't realize at the time the fuel pump should have been replaced.
Old Sep 13, 2007 | 10:21 AM
Vette Mag's Avatar
Vette Mag
Cruising
Thanks for the feedback. A few questions:
- How much boost were you running?
- What was the mileage on your engine at the time?
- And finally, how did the engine hold up after the install?
Regards,
Jay
Old Sep 18, 2007 | 10:25 AM
Vette Mag's Avatar
Vette Mag
Cruising
Should I deduce from the lack of responses that these are not popular upgrades?
Thanks again,
Jay
Old Sep 18, 2007 | 02:38 PM
RVY's Avatar
RVY
Furnished pulleys produced about 8lbs boost.
There may have been approx. 22,000 miles on the toy.
The motor held up well. I lost the rings after I went to 10 lbs boost.
Personally I had more fun and pleasure at this point in time then when I went to 586 rwhp.
Old Sep 18, 2007 | 05:11 PM
lead foot 85 vet's Avatar
lead foot 85 vet
I saw a 100 rwhp on my stock l98 at 8psi.......the lt1 has a better intake system, so you'll see a bigger gain..........p600b procharger.
Old Sep 18, 2007 | 09:36 PM
LTxDave's Avatar
LTxDave
Thanks again,
Jay
I think most folks on this forum are looking for more HP than the basic procharger or vortech kit provides. I know that going putting a supercharger on my GS and heading out with around 400 RWHP would be disappointing when a basic upgraded LS1 with a cam will easily exceed that number. I went ahead and built an engine ready to handle a decent amount of boost. Now if I could only get the time to finish the engine, install, and tune the combo...
Old Sep 22, 2007 | 02:15 PM
lisoundsvette's Avatar
lisoundsvette
Default here is what got me into the 10's
1994 CORVETTE
CONVERTIBLE
COMPETITION YELLOW (1 OF 834)
BLACK LEATHER INTERIOR
BLACK TOP
DRIVETRAIN:
ORIGINAL MOTOR STROKED TO 383 CU.IN
FORGED ROTATING ASSEMBLY WITH 9 ½ COMPRESSION
COMP CAM BLOWER ROLLERCAM CRANE 1.6 ROLLER ROCKERS
PORT POLISHISHED AND BENCHED FLOW HEADS MANLEY VALVES
Lt-4 INTAKE MANIFOLD PORT MATCHED AND POLISHED
BBK 58 MM THROTTLEBODY
VORTECH S TRIM SUPERCHARGER POLISHED
UPGRADED PULLEY MODIFIED AIR VALUTE
GASEOUS “ALKY” INTERCOOLING
DUAL WALBRO FUEL SYSTEM INTANK AND INLINE
42 LBS HIGH FLOW FUEL INJECTORS
CRANE IGNITION W/ TIMING BOOST CONTROLLER
MSD IGNITION COIL MSD 8. 5 MM WIRES
AUTOMETER BOOST AND FUEL PRESSURE GAUGES
MANUAL FAN CONTROLER
TPIS LONG TUBE HEADERS 1 ¾ HEAT COATED
3 INCH EXHAUST X PIPE MAGNAFLOW MUFFLERS
LEVEL 10 PTS 4L60E TRANSMISSION 2800 STALL CONVERTOR
DANA 44 UPGRADED REAR W/ 354 GEARS
HEAVYDUTY REAR SPRING BILSTEIN SHOCKS
EXTENSIVE DYNO TUNING 496 RWHP 540 TORQUE ( CONSERVATIVE #’S)
ran 10.98 1/4 124mph 1.52 60ft
and i am thinking of selling it..
Old Sep 22, 2007 | 02:57 PM
lead foot 85 vet
Originally Posted by lisoundsvette
1994 CORVETTE
CONVERTIBLE
BLACK TOP
DRIVETRAIN:
How many lb's of boost?
Old Sep 24, 2007 | 09:23 AM
lisoundsvette
12 pounds of boost on my 383 s/c
Old Oct 6, 2007 | 09:48 PM
Pickups1's Avatar
Pickups1
1994 LT1 6spd Procharger
With no other mods - 365 rwh @ 6-7lbs boost.
Mileage was about 23K when I had it installed in 2001. Now has 40K. Other than replacing the clutch (about 2 months after installation), no dependability issues whatsoever.
Have not had it dynoed since I installed long tube headers and 3" exhaust, but I would guess about 15-20hp increase.
Old Oct 7, 2007 | 12:53 PM
qwiketz's Avatar
qwiketz
I never got my car dyno'd with the stock vortech setup. i couldn't get too much boost out of it due to belt slip. The max I saw was 6 lbs.
Old Oct 10, 2007 | 12:21 PM
MislMan's Avatar
MislMan
Jay ... this may relate. I installed a Powerdyne SC kit on my 1995 Trans Am. Sotck LT-1 with MAC headers, stock cats, 1.6 roller rockers, and 58mm TB. I deleted the FMU set-up and added 36 lb. injectors. I pullied the PD head unit to put out 6-7 lbs. boost. I tuned the set-up using LT-1 edit. Motor made 429 RWHP and 440 RWTQ.
This was on a 1995 Pontiac Trans Am LT-1 motor with 4L60E tranny (stock torque convertor) and 3.73 gears. Running on Nitto 275x17 tires the T/A ran a best of 11.86 at 119 MPH and was usually in the 11.95 to 12.05 bracket on a weekly basis. I live in Orlando Florida so heat and humidity plan a part in the times.
The really coll part was that you simply couldn't hear the Powerdyne unit at idle or even when stomping on it. Except for the polished custom wheels is was a real sleeper. Especially with a 50+ year 'ol man at the wheel (just teachin' the youngin's some repsect ;-)
I am now in the market for a Vortech SQ system to install on my '95 LT-1 Corvette Coupe. Anybody have a good line on a very good price? Need another project car for a SC install? It is a stock LT-1 with auto and 63K mles on the clock.
New car show in the signature.
Later ... Larry S.
Old Oct 10, 2007 | 01:12 PM
dr.juice's Avatar
dr.juice
1995 Corvette, white
6 spd
-stock block std. bore
-stroked to 377cid
-forged internals (eagle crank, lunati rods, JE pistons/rings)
-9.3:1 comp.
-blower cam
-1.6 crane rockers
-AFR/TPIS heads
-Cometic head gaskets
-BBK 58mm throttle body
-LT4 intake
-long tube headers w/x-pipe
-single Aeromotive Eliminator fuel pump
-Procharger D1SC w/std. a2a intercooler(not good...BIG restriction)
-cog pulleys
N/a #360 rwhp and s/c with 18 psi of boost: 651rwhp/ +/-790rwtq.
Old Oct 10, 2007 | 05:18 PM
Brand-X's Avatar
Brand-X
I was seeing 385 rwhp on 7 psi...
Old Oct 26, 2007 | 03:42 PM
yzfr1mike's Avatar
yzfr1mike
Default Procharger HP Test
Hi- I have a 1992 Automatic car with a procharger, forged internals in motor, AFR 190 heads, and a 114 LC comp cam at .544 lift and 220/230 degrees at 0.050 lift. after tuning it made 496 HP and 494 torque. I made about 10 PSI at 6000 rpm with belt slippage.
Also have 48 lb. injectors, 255lph pump in tank, and a dyno tune by PCM for Less.
TPIS Headers, custom 3 inch "X" pipe, and 3 chamber flowmaster mufflers, and a 58mm throttle body.
With the stock motor and 7 PSI boost it made 436/436 HP and Torque. This motor broke while using the FMU on the car.
It is a lot of fun and very quick.
Mike
To ProCharger/Vortech Dyno Numbers?
Old Oct 26, 2007 | 05:46 PM
kverges's Avatar
kverges
I have a Vortech car, but it is not lightly modded, as it has CNC LT4 heads & Intake, Lingenfelter cam, JE pistons and a compete fuel system. OH, and Water injection But it made, with an agressive tune, 529 rwhp and 505 tq, I haveit detuned for DD duties to about 500 rwhp. It will pull as much as 128 mph in the 1/4 on street tires and a good day, consistetnly 123-125 mph.
Old Oct 27, 2007 | 08:03 AM
EPP's Avatar
0EPP
Former Vendor
Thanks,
Jay, here is one customers cars that we added an ATI ProCharger to. Bob
http://www.exoticperformanceplus.com/hotCars.php?car=56
Old Nov 4, 2007 | 07:53 PM
bogus's Avatar
bogus
I suspect the reason most folks DON'T do a supercharger on a C4 is cost... these are expensive kits... and C4's are cheap-o-rama...
