Antenna Mast Replacement Question
Old Nov 10, 2001 | 11:25 AM
Frank C's Avatar
Frank C
Default Antenna Mast Replacement Question
I got the new mast etc and plan to R&R today. Does the rubber gromet in the body recess just pop out? I believe this has to be removed before you can get to the mounting nut. (Power antenna-91 vert) Thanks, Frank
Old Nov 10, 2001 | 12:40 PM
Frank C's Avatar
Frank C
Default Re: Antenna Mast Replacement Question (Frank C)
Never mind. Thanks anyway. I see that you just push the provided tool onto the plastic nut at the correct angle and remove. Of course now the motor won't take up the new nylon cable. Another 10 minute job that will take all day. Thanks, Frank
