I just installed my new motor along with Jeb's intake. Using the stock or the Super Ram cable bracket, my throttle cable is too short. I guess Jeb mounted the braket support in the wrong place. Can I buy a new cable and insert it into the exsisting plastic tube? I have an 89 and where it connects the the throttle body, it has a cylinder shaped piece connected to the cable.
I'm using a Victor Jr. & carb on my '90 C4, changed throttle cable to an '86 Monte Carlo/Malibu unit. Works fine, but may need travel adjustment depending on TB/carb pivot point.
Thanks. I got if figured out. I had an extra cable that Arizona Speed and marine sent me. I had problems years ago with their TB and the miniram. I'm all set now. Just waiting for headers.
Right on! Do you have any power goals Jason with this new motor?
