What year is your car? On my 86 those are the MAF burnoff and MAF power relays ...(Mine are two different part #'s but on most others you can interchange them ...like $8.00 at autozone/checker).
Speaking of which, mine kinda look like that =) What's the best way to fix the insulation? (just getting into this do it yourself fixing stuff ...).
_Eric
Originally Posted by 86PACER
MAF relay. Check the wire insulation at the connector. Over time, the insulation can shrink back, exposing bare wires.
_Eric
There are two ways. Snip the wires even for a fresh start with wire cutters, then just transfer over the metal connector leads.
Or
Unclip each terminal from the plastic harness end, and slide a piece of heat shrink over it. Then heat the shrink to insulate the exposed end.
One way I've found that works is the tool handle dip. If you use a small brush or Qtip, you can cover each wire seperatly and they're waterproof. You can find it at most tool stores. Most of the big chains have it.
