Anyone know what the pressure is supposed to be at the front and rear calipers? Got an '87 showing 1000psi at the front and one rear and a leak down on the other rear to 500psi.
Thanks,
Thanks,
There is a kit for this. I always thougth there was a 20% difference between the front and back. Can't seem to find any numbers for what it should be. Obviously have some brake issues.
Bondo
Bondo
.....do you have a link or name or cost or anything having to do with the device or tool you are measuring pressure with?
I remember, years ago, looking thru an EARL's SUPPLY catolog/listing, and they had some military/aerospace surplus guages for sale. I noticed some hydraulic high pressure guages, with small NPT fittings, that were rated 1,000 up to 5,000 psi measurements. I assume some could be used to measure higher pressure in automotive brake systems?
Waekon makes the kit for testing ABS pressures...
FYI
Bondo
