Brake fluid
Old Nov 10, 2001 | 11:13 PM
Stevebra's Avatar
Stevebra
8th Gear
Default Brake fluid
I was going to change the fluid in my 92 and wondered if anyone had a prefrence on types. Any problems with switching to a synthetic?
Old Nov 11, 2001 | 04:13 AM
Hawaii89vette's Avatar
Hawaii89vette
Default Re: Brake fluid (Stevebra)
Try the synthetic brake fluid. I found a big bottle of synthetic brake fluid at Walmart for pretty cheap. The synthetic should stay much more stable than the regular stuff. The synthetic brake fluid will mix ok with the regular stuff.
-Tim
Old Nov 11, 2001 | 02:08 PM
93 ragtop's Avatar
93 ragtop
Big problem switching to synthetic. The two fluids are not compatable. It will cause problems with seals etc. Change the fluid often. But use a mineral based fluid.
Old Nov 11, 2001 | 05:43 PM
Hawaii89vette
Default Re: Brake fluid (Red 86 4+3)
All the synthetic brake fluids that I have seen (rated DOT3 and 4) are fully mix compatible with the regular stuff. You are probably confusing it with the silicone brake fluid (I think that's Dot 5). The silicone brake fluid will not mix at all. But the synthetic DOT3&4 brake fluid is totally mixable.
-Tim
Old Nov 11, 2001 | 07:56 PM
vettenuts's Avatar
vettenuts
Default Re: Brake fluid (Hawaii89vette)
I have used the Valvoline synthetic many times. It will mix with any DOOT 3 or 4 fluid. The wet boiling point is pretty high. Another good fluid is the Ford fluid.
Old Nov 11, 2001 | 10:24 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Motul 600 here. Outstanding boiling temps wet and dry. Not exactly cheap. Spent 25.50 for two bottles and that was enough to do front and rear.
Old Nov 11, 2001 | 10:55 PM
black85's Avatar
black85
I just changed to a different type called Castrol heavy-duty. I think it is synthetic or partially so. My mechanic recommended it. It replaces all dot3 and dot4, but it is not the dot5. I have heard bad things about the dot5.
Changing my brake fluid made all the difference in the world for my brakes. They used to have severe fade on the track, but now they are toe touch in all conditions (except stone cold).
[Modified by black85, 8:58 PM 11/11/2001]
Old Nov 12, 2001 | 06:06 AM
93 ragtop's Avatar
93 ragtop
-Tim
My apoligies,
I was thinking silicone fluid. Sorry for confusing the issue.
To Brake fluid
