Question about LT1.....?
Old Sep 19, 2007 | 08:23 PM
rssshen vette's Avatar
rssshen vette
Default Question about LT1.....?
I have a 383 (see signature). I just purchased a complete LT1 intake on Ebay( $125.00) to replace my TPI. My question is this .... will the stock injectors and throttle body feed enough air and fuel for my set up? I have a mild cam (duration 220/224 .502/ .525 lift @.050) Or Will I need to upgrade to bigger injectors and throttle body?
Old Sep 19, 2007 | 09:23 PM
bogus's Avatar
bogus
The stock throttle bodies are the least of your concern.
I would get 24# Ford Motorsport injectors (matched) and be done with it.
You will need a tune...
Old Sep 20, 2007 | 12:15 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I agree with Bogus. You can go to a 52mm TB later. If you ever plan on going bigger, go ahead and have the intake bored for the 58s.
Old Sep 20, 2007 | 05:53 AM
93 ragtop's Avatar
93 ragtop
Your signature shows 24lb accels. If the only thing you are changing is the intake, you may be ok, unless you plan to see more rpms. Personally I would contact Alvin and ask him.
To Question about LT1.....?
