Do Bosch Platinum Gap The Regular Way?
Old Nov 11, 2001 | 02:22 PM
92corvette's Avatar
92corvette
Default Do Bosch Platinum Gap The Regular Way?
I just pulled my first set of Bosch Platinum's out of the box. The gap out of the box is less than .044 and the normal gap for my car is .050.
I'm afraid I'm going to break the insulator if I try to open the gap.
Two Questions:
1. Should the platinum's be gapped like stock plugs at .050???
2. Do I need to worry about breaking the insulator by wedging my gauge betwwen the tip and insulator???
Thanks,
Old Nov 11, 2001 | 05:10 PM
92corvette's Avatar
92corvette
Default Re: Do Bosch Platinum Gap The Regular Way? (92corvette)
Never mind...I found the answer...
Old Nov 11, 2001 | 05:15 PM
scorp508's Avatar
scorp508
And was it "pre-gapped from factory"? :)
I've put 2 sets of them in a couple friend's imports (supposedly they're good for them), and they have all so far been perfectly gapped right out of the box.
Old Nov 11, 2001 | 05:32 PM
92corvette's Avatar
92corvette
Default Re: Do Bosch Platinum Gap The Regular Way? (scorp508)
No they weren't pre-gapped based on the info I found on the net. And they weren't all the same out of the box. The gap out of the box was from about .039 to .045. I gapped them all to the recommended .050 for my LT1. I certainly hope the info I found was correct and I should have re-gapped them. I guess I'll find out soon. :rolleyes:
Old Nov 11, 2001 | 05:33 PM
scorp508's Avatar
scorp508
Well that is interesting, at least you have the piece of mind that they are all the same now! :)
Old Nov 12, 2001 | 02:46 AM
fade_to_black's Avatar
fade_to_black
Default Re: (scorp508)
I just bought some NGK TR55IX's for mine and I pulled the old ones out. The previous owner put the Bosches and Every plug was gapped at .040!! I guess he assumed they were pre gapped....
Old Nov 12, 2001 | 08:56 AM
92corvette's Avatar
92corvette
Default Re: (fade_to_black)
Did it run OK with all the plugs gapped at .040???
Heck, the info I looked up could be wrong and I may have to close the gap some, I dont' know. I'm really starting to wonder now.
Old Nov 12, 2001 | 01:19 PM
fade_to_black
Default Re: (92corvette)
It was running a little rough...not bad, my grandfather builds racing motors for a living. His books said .050....That is what I am going to gap my new plugs at..... :cheers:
To Do Bosch Platinum Gap The Regular Way?
