No Brakes! Help!!!!!
After driving on the highway without a problem for about 25 miles, I go to exit and while braking the pedal falls almost to the floor. I quickly release it and pump it and the pedal rises and the car stops, but the brake warning light illuminates. I continue with caution, the light goes out, so I figure its low on fluid. I hit the brakes again and the same thing, pedal almost to the floor and the light comes on. The car does come to a stop though, although a bit nosey. I hit the brakes once more, pedal to the floor, car stops but now the light won't go out. I limp the car home and get into the garage. Its a miracle she stopped before hitting anything.
Anyway, I pop the hood and check the level. The front is full, almost to the cap. The rear is a little low, but not anywhere near the minimum level. The front brake lines are dry and the master cylinder and all lines connecting to it are dry as well. I didn't check the rear yet but I figure if the rear fails, the car should stop better than it did being the front does most of the work. The brake pads and rotors are fairly new, have about 3000 miles on them, if that.
Any ideas what this could be? Could it be the M/C? Air in the system? Bad booster? Any tests I can run to determine the problem? HELP!
1...check fluid level...2...check all lines at m/c for leaks...3...check back of m/c and ft. of booster for any signs of brake fluid leakage....4...remove the rear wheels first (since it is the back reservoir that is low) and check flex lines and calipers for any leakage (pistons, bleeders)....5.....IF none found, do the same with fronts....if none found and assuming that you HAVE NO AIR in lines to start with and m/c was full, then i'd say that your m/c just took a dump so, REPLACE it........i just went through this 2 days ago where the rear seal blew on the m/c......
While your in there, purchase a set, (4) "SpeedBleeders". They are cheap and make it a one man, quick, job.
......my post was assuming that he didn't have air in the system to begin with and fluid level was fine...theer has to be a reason as to WHY air is suddenly in the system and his symptoms (although they can mimic others) are/were identical to mine...replacement of any caliper or master cylinder should require a bleeding process and although s-bleeders will work for a "one man band" are not necessary but of choice and should work well...
Anyway, after I posted last night, I checked everything out again. The entire front is dry, no sign of leakage at the calipers, lines, m/c or booster. I pulled the vacuum line off the booster and it was dry, no sign of fluid in there. I went to the back and all was dry there too. I pulled both reservoir caps off and hit the pedal. An air bubble came up from the front reservoir. I hit the pedal a few times and it bubbled each time. The rear reservoir level isn't low. Its a tad below Max but when you compare it to the front reservoir, it looks low because the front is almost to the top. There has to be air in there and I'm thinking the air is blocking the fluid from travelling.
So if I open up the bleeder screws on the front calipers and bleed them out and it solves the problem, I still have to figure out how air got in there in first place being no lines were ever opened and the calipers are still originals (at least to me, I never replaced them or removed them), right?
On another note, I'm looking into getting the SpeedBleeders because I will be doing this all myself. What are the sizes of the bleeder valves on the 85 C4? Are they metric?
I got some prices on m/c's already and they aren't cheap and no one has them in stock
so it looks like I'm grounded this weekend.
Next question, the booster looks dry. The hose is dry and it seems to be ok. How can I determine if brake fluid got into it?
