GM Bare Block for Build?
Why on earth would you want to pay to throw away .030" worth of wear surface, cylinder wall strength, heat dissipation capability, and/or meat for a future overhaul, by boring a brand new block .030" over sized? For the silly 6, or so, cubic inches???
RACE ON!!!
RACE ON!!!
... [erroneous information removed]
When building a street motor on a budget, go with a good "seasoned" used block if you can.
A 350, stock stroke, plus stock 4.00" bore = 350 cid.
A 350, stock stroke, plus .030" overbore = 355 cid.
A 350, with a 3.75" stroke, plus stock 4.00" bore = 377.
A 350, with a 3.75" stroke, plus .030" overbore = 383.
With a stock stroke the .030" over bore gives you 5 cid. With the stroker crank it gives you 6. As I said, "Why on earth would you want to pay to throw away .030" worth of wear surface, cylinder wall strength, heat dissipation capability, and/or meat for a future overhaul, by boring a brand new block .030" over sized? For the silly 6, or so, cubic inches???"
RACE ON!!!
No. I'm saying that when i read something like that,written by someone who apparently is not that knowledgeable, I assumed he was thinking 383 as 30 thou' over is a start point.Two posts later I was proved right.You really have a way about you that gets peoples backs up for no reason.
RACE ON!!!
At least the mesage is good.
RACE ON!!!
RACE ON!!!
