My wife and went out tonight in the 88. While idling my blinkers would quit working and I could see the panel lights go dim. When moving or putting the car in park, everything would work again. However, when in park the blinkers were slower than when driving down the road. My first 2 thoughts were battery or alternator, but I am not for sure.
When idling while in gear, the voltage would go down to 10, then jump back up to about 13.5 when driving down the road.
I have done some searches here but apparently have not put the correct items to search for. I cannot find anything directly related to this problem. I'm still new to this and have only had the car for a week.
BTW, thanks to everyone for all the great posts. I have found many other things I am interested in.
Even at idle (in gear, brake on) you should see 14.3 volts, alternator cold, and this voltage will drop to 13.3 volts when the alternator gets to its normal operating temperature (normal operation). If the alternator is not charging the battery (and at 10 volts it is not charging your battery), then you should see the red battery symbol on the dash lit up. Normal idle rpm is 700-800 (unusually low rpm will cause low alternator voltage). I would suspect a defective alternator. Take the alternator to a parts place, most will test them free (tell them it has no output at idle rpm). Check the nut on the alternator output bolt for tightness (don't touch your wrench to ground or you will blow out the fusible link on the output wire).
Check for rust/corrosion and clean ( with wire brush) battery terminals, alternator terminal, ground terminal at engine block (beside oil filter, its a big nut). Check continuity with DVM on wires (battery disconected) leading from positive battery term to alternator red wire term and negative term to alternator housing. Run the engine and see if voltage comes back up to 14.5volts at idle. Post results and we will go from there.
Regulator. Wouldn't under drive pulleys make it spin FASTER, not slower?
....i run a smaller pulley on mine which results in the alt spinning faster.....i occasionally still drop to close to 12vdc when everything is on at idle and in drive....
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Huh? IF the crank pulley is smaller than stock, the rest of the accessories will turn slower not faster. Thats why your alt is dropping offline at idle.
I'd love to run my March underdrive pulleys all the time. But the street drive ability is less than desirable. Especially at night.
....NOPE!.......you are misunderstanding what i am saying....i have a SMALLER pulley on my ALTERNATOR and therefore it goes around faster then if with the "standard" pulley......i was never talking about any of the "drive" pulleys, just the one on my alternator!
I put on a new alternator. They checked it at AutoZone and said it was not putting out at all. (Like an old girlfriend) Anyway, it seems to help in idling while in park, but I still see a drag when in gear at a stop. The gauge goes down to 11.5 at times, which is still better than the 10.? it was going down to. When I turn off the air, then it kicks back up to 12.5, sometimes going to 13. Seems the air is putting a real drag on the system.
......my alternator is brand new as of last sunday and with a/c, radio, both cooling fans going, etc.......mine does about the same thing (12.3vdc) so, i am not concerned as i have checked all connections and grounds and am running a smaller pulley on the alt...
Should get your battery tested too. Sounds like it's not holding a charge. Also it seems to me that you might have a circuit shorting to ground. Test the battery first and we'll go from there.
It would not be unusual to see battery voltage with all the accessories on. The 105 amp alternator is only putting out 30 to 35 amps at idle. The HVAC blower can sap 25 of that, the main fan 10 and with the headlights and radio on, the alternator isn't going to keep up. GM will tell you it's normal. In fact they issued a Bulletin telling Dealers that they were not going to reimburse them for warranty claims if the only complaint was that the lights were dimming at idle. The only solution is a bigger alternator. In the interim, you can verify the gage readout by checking the voltage at the Battery with everything on and the car in gear. You can also check it on both sides of the ignition switch as corrosion between the contacts will make the gage read less. Finally, if you've rigged both fans to run for cooling, get it back to where only one fan is engaged. With both going, it's simply adding to the problem and once the voltage drops, they're going to slowdown and your coolant temps will climb.
A cyclic event that takes place usually in the spring is all the threads about batteries and alternators. (Leading into the winter is heater core hell.)
The Corvette that is not driven on a daily basis is going to tax the alt in an attempt to charge the battery when driven. Add to this the lame (105 amp) standard alt that the General equipped us with.
So the alt is working harder than it should and the battery is being cooked during each weekend outing. Its no wonder that the average C4 Vette battery lasts only one year. And its replacement is usually followed closely with an alt exchange as well.
The remedy is to use a battery tender. An inexpensive device that is plugged into the wall and then to the battery during the "rest" periods. I started using one of these two years ago and have had no further batt/alt problems. "Rose" gets about 6 outings a month now and the alt stays within normal temps after running.
When you say a battery tender, are you referring to a trickle charger that only cuts on when the battery needs a little charge? I use one on my boat during the winter since it is left in a slip all year.
Thanks to everyone for all the great feedback. This forum is the best. I did notice today the car started better since putting the alternator on. Sounds like the battery is now staying charged better than it was before.
