I used '96 fronts on my '89, but had to file a small notch in the little bracket on the frame where the hoses attached to the hard lines for them to fit correctly, the "alignment notch" was off a good bit.
I have an opportunity to purchase braided lines from a 96 for my 89 at a great price should/can I do it????? I can't seem to get a straight answer from anyone I talk to!!
I guess you can not do that.
I was browsing the Goodridge , Russell and Earls catalogues for stainless steel lines ( braided) and I found that 94 to 96 are the same, but I almost remember that 91 and 93 are the same. So as you can see 94-96 would be a different fit compared to the first C4's.
Looked at Russell's catalogue and found this:
84-87 uses part# 692010
88-92 uses part# 692020
94-96 part# 692180
97-04 part# 692190
As you can see they market different kits for different year groups, hope this serves
94-96 part# 692180
97-04 part# 692190
But WHAT is different about them? in Russells catalog they also state that they will nto fit the ZR-1, when the ZR-1 uses the SAME lines as the regular C4..
