Air Conditioning clutch replacement????
Old Sep 27, 2007 | 09:02 PM
noyo55's Avatar
noyo55
Default Air Conditioning clutch replacement????
My air conditioning quit. When turned on I have juice at the plug on the compressor but it will not engage. Multimeter says 12 volts. How much of a job is it to replace the clutch?
Old Sep 27, 2007 | 09:12 PM
Da Mail Man's Avatar
Da Mail Man
...not too easy but, talk to sunCr as he may have some ideas....
Old Sep 28, 2007 | 09:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Welcome aboard
Don't know what year you have or do I have any experience with the clutch, but I can give you some info from my 86.
http://members.shaw.ca/agent86/AC%20...20Overhaul.pdf
Old Sep 28, 2007 | 04:01 PM
SunCr's Avatar
SunCr
You need to post the Year and system - electronic or manual. Most a/c clutches have fused voltage anytime the ignition is on. Controls then supply a ground as long as the system has enough gas for it to safely engage. You can test yours by jumpering it to ground. Seriously doubt it's a clutch problem - more than likely all your gas is gone or the controlling device is shot.
To Air Conditioning clutch replacement????
