a/c help
Old Sep 24, 2007 | 12:36 AM
Roger Willingham's Avatar
Roger Willingham
Default a/c help
I am having a small (big) problem with the a/c. The a/c blows cold and works great except when I first start it up. It will take up to five (5) minutes befor the air blows out of the dash or floor vents. It blows cold air through the defroster vents for a long time at first. This happens on any selection , auto or other, of the controls.
Thanks in advance for solution....
Old Sep 24, 2007 | 12:41 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
This sounds like the famous vacuum line check valve problem...but I am not 100% sure if your engine had the same thing as the LT1 and earlier cars.
Aside from that,there are plastic vacuum lines and theres a check valve on the lines on the side or back of intake manifold,depends on engine,year,etc and it looks like a 2-3 way funnel,its very small,and when they stick or go bad,the a/c will blow out the defrost most of the time or take a long time to switch over.Just wanted to share that info in case it is a vacuum problem with the check valve.
Im sure someone will post tonight or tomorrow to aid ya more.I seen your sig and it says an LT4 so be sure to include your correct engine year and info. If I assumed wrong.
Old Sep 24, 2007 | 06:54 AM
Da Mail Man's Avatar
Da Mail Man
.....i tend to agree as it sounds like a leaking or partially detached line or problem at the ck valve...
Old Sep 27, 2007 | 12:17 AM
Roger Willingham
Default check valve
Thanks for the replies, Yes I do have the LT4 engine.
I did change the little three way check valve under the right side injector cover last month thinking that it would solve the problem as it was broken. I appeared to work a little better but still has a problem. I'll check the shop manual for other areas.
Any other replies will help
Old Sep 27, 2007 | 06:56 AM
larryfs's Avatar
larryfs
the 96 problem is specific to the 96. it's a programmer box problem under the dash.
Old Sep 27, 2007 | 12:46 PM
SunCr's Avatar
SunCr
Still sounds like a Programmer defect. System is designed to purge air on startup through the heater ducts to prevent window fogging. Shouldn't take forever. Programmer controls that - it's the Processor - and it gets it's signals from the Dash Controls over serial data lines. There is nothing in those signals (that I can think of) which would make it act the way you describe it. Since you've verified that vacuum is good in the engine compartment, you need to make sure it's good at the Programmer. Assuming it is, I'd pop for a rebuild.
Old Sep 27, 2007 | 12:55 PM
larryfs's Avatar
larryfs
That's over a $1000 for a GM rebuild.
Old Sep 27, 2007 | 01:16 PM
SunCr's Avatar
SunCr
Then - after you verify vacuum at the Programmer - you might just want to spend the flat rate to have it diagnosed with a bi-directional scanner.
Old Sep 27, 2007 | 01:20 PM
larryfs's Avatar
larryfs
There is no need for that. I will repair your box for $200, and it'll work good as new.
(this only pretains to 1996)
Old Sep 27, 2007 | 10:00 PM
Roger Willingham
Thanks Guys
Hopefully I'll get to look at it in the next couple of weeks.
To a/c help
