Headlight problem: driving light switch activates high-beams!!
Old Sep 24, 2007 | 01:02 PM
95wht6spd's Avatar
95wht6spd
Default Headlight problem: driving light switch activates high-beams!!
My friend and I put in E spec lights and used heavier gauge wire, relays, fuses, etc. We left the old wire intact, and only cut the wires at the connector that plugs into the light housing.
Why would the driving light switch also activate my high beams? We didn't even touch the driving lights! The driving lights stay ON when the high beams are on too! Yesterday I noticed that my headlights stayed on when down, the car was off, and the light switch was off! I had used the light and driving light switch to signal someone in the day time. I turned the key to ON, turned the lights on, and operated the driving lights a few times, then turned every thing off and the light went off as usual.
Any ideas?
Old Sep 25, 2007 | 12:03 PM
95wht6spd's Avatar
95wht6spd
TTT
No one has any ideas?
Old Sep 25, 2007 | 12:27 PM
jfb's Avatar
jfb
You may have interchanged the headlamp wire and the parking light wire, but I can better answer when I get home and have access to the wiring diagram.
Old Sep 25, 2007 | 11:18 PM
jfb's Avatar
jfb
I am assuming the 95 headlight/fog light wiring is like my 87 and if so, you have made a connection between the high beam dimmer switch wire and the fog lights in your installation.
Old Sep 26, 2007 | 09:35 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Find a schematic. My memory tells me that the driving lights are linked to the headlight circuit on newer C4's.
Old Sep 26, 2007 | 12:21 PM
95wht6spd's Avatar
95wht6spd
Ran all new wires connected to the alternator.
Only place we cut wires was at the headlight connector, this shouldn't affect the other lights, but it does! When you turn on the highs the driving lights will go off when stock, but now they stay on.
Old Sep 26, 2007 | 03:19 PM
AGENT 86's Avatar
AGENT 86
This is a cut and paste from the driving light upgrade info from tech tips.
NOTE: Research on the driving light subject indicates that some C4�s have their driving lights grounded directly to chassis ground. This setup is ideal for the above modification. Other C4�s have their driving lights grounded through the headlight high beam filament. What this does is that it will automatically shut the driving lights off when the high beams are turned on.
Old Sep 26, 2007 | 05:57 PM
95wht6spd's Avatar
95wht6spd
I'm confused, do I have the chassis grd, because both lights stay on, but it says this is ideal? If I have the other grd, why do both lights stay on? I think we are on the right track! We did ground to the fram, I think the same place it was origianally grounded, I remember cleaning the nut.
Old Sep 26, 2007 | 11:16 PM
jfb's Avatar
jfb
One clue is if the headlight is not at full brilliance then your driving light is using the 12v to the high beam filament for ground and a higher power driving light will cause the high beam to come on but not at full brilliance.
Old Sep 27, 2007 | 12:09 PM
95wht6spd's Avatar
95wht6spd
I wouldn't be able to tell, the low's are brighter than standard highs, and the highs....fagetaboutit! I turned them on once and the car in front was to close so it went up in flames!
Old Sep 27, 2007 | 04:20 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Check the wiring diagram in your shop manual.
In the case of my '90, the fog lamps are grounded thru the highbeam circuit. When I added my Hella 90/130s and rewired everything, I had to redo the grounds but I can't remember exactly what I did... it's been too long. Even after rewiring, my high beam indicator comes on when my fogs are on but the h-beams are off - fixing that was too much trouble.
Check your FSM to make sure you get it wired correctly - the circuit is not as simple as one would think. The '86 was easy to upgrade (same stuff as the 90) because it did not run the grounds the same way.
Old Oct 7, 2007 | 10:49 AM
95wht6spd's Avatar
95wht6spd
Well my friend and I spent hours on this, tried different grounds, read the FSM, etc. No luck. Now the fog lights don't come on at all!
My friend thinks it's the fog lamp relay, we couldn't find it! Where is it? It is supposed to be near the cruise control module. FSM says it is in the passernger side area under dash? We could access anything there, even removed the fuse panel!
Old Oct 8, 2007 | 09:10 PM
95wht6spd's Avatar
95wht6spd
Ttt
Old Oct 9, 2007 | 06:38 PM
95wht6spd's Avatar
95wht6spd
Also where is the FUSE for the fog/driving lights? It seems I have seen this listed somewhere, but we could not find it!
To Headlight problem: driving light switch activates high-beams!!
