84 radiator replacement
Old Sep 24, 2007 | 06:59 PM
marksp's Avatar
marksp
Default 84 radiator replacement
Hey guys my 84 has a cracked tank on the radiator, where should I get a replacement? Napa has one for $200, modine brand. Who has the best deal on an all aluminum version? How big of a PITA is this gonna be?
Mark
Old Sep 24, 2007 | 07:19 PM
JLeatherman's Avatar
JLeatherman
If you can spare the extra money, nothin's finer than a DeWitts radiator. So well made you hate to cover it with the shroud.
Old Sep 24, 2007 | 08:01 PM
CFI-EFI's Avatar
CFI-EFI
You don't need an all aluminum radiator. They run upward to about $500.00. That Modine you found at NAPA is an excellent OE replacement and will serve you well, but it is over priced. You should be able to find the same exact radiator for $150.00 or less. However, with no more than a cracked tank, all you need to do is have that tank replaced. If you'll take the radiator to the rad shop, they should replace the tank, parts and labor (with the radiator already out) for less than half the cost of a radiator. Let your fingers do the walking.
RACE ON!!!
Old Sep 24, 2007 | 08:59 PM
armybyrd's Avatar
armybyrd
Where can you buy a Dewitts radiator? How much do they go for?
They any better than a becool or a griffin?
Old Sep 24, 2007 | 09:36 PM
NitrousSam's Avatar
NitrousSam
Default 84 Radiator
If you need an 84 radiator I have one that I took out of my 84 before I installed my 406.
Old Sep 25, 2007 | 12:17 AM
MrRenoman's Avatar
MrRenoman
I've bought a few radiators from www.radiators.com They're reasonably priced and usually arrive the next day. Otherwise you'll have to go local and spend more which is sometimes ok because you can see what you're buying. Replacing the tanks is do-able at any reliable radiator shop. Some may say the discount radiators are junk but I've had good luck with the few I've bought. I do know the Vette radiator I bought for the '85 came with the coolant level sensor plug in it that was used in later models. Didn't have to do anything with it but it did fit the '85 just fine.
Art
Old Sep 25, 2007 | 12:54 AM
staugur's Avatar
staugur
Mark
all aluminum $103.00 with free shipping.www.autopartswarehouse.com. It's the SILLA.
Old Sep 25, 2007 | 05:17 PM
marksp's Avatar
marksp
WOW, $103 ain't bad.
Thanks guys
Mark
Old Sep 25, 2007 | 06:43 PM
CFI-EFI's Avatar
CFI-EFI
Art
Just be wary of a "bargain" radiator that doesn't have an aluminum core. Some of the "off shore" will fitters tout radiators that have more rows of tubes and say that they cool better than the stock radiator. The problem is, it TAKES more rows of tubes for a copper/brass radiator to equal an aluminum radiator.
I am not saying that www.radiators.com is a bad place to buy. I'm just saying that regardless of where you buy, watch WHAT you buy.
RACE ON!!!
To 84 radiator replacement
