install balancer hub?
Old Sep 25, 2007 | 11:08 AM
davidf4925's Avatar
davidf4925
Default install balancer hub?
how do you install this part, I used a puller to get it off, do they make and installer tool to put it on or what,, 95 a4. thanks
Old Sep 25, 2007 | 11:41 AM
RedCorvette1988's Avatar
RedCorvette1988
Are you talking about the hamonic balancer? It is on the front nose of the crank. Under the water pump. If you are Yes they do make a installer. I think most part places would have one. I ordered mine from a magzine.
Good Luck
Old Sep 25, 2007 | 12:05 PM
STL94LT1's Avatar
STL94LT1
I used two grade 8 bolts. One stock size and length, and the other about one inch longer. Then used those to reinstall the hub. Start the hub with the longer one, and then tighten with the shorter bolt. Pull the short bolt out, and torque the stock one.
Old Sep 25, 2007 | 03:33 PM
JAKE's Avatar
JAKE
I believe AutoZone loans the installer.
While you're there (should you choose to go), take a look at their big, place-mat looking display that shows all the tools they loan. Could come in handy in the future.
Jake
Old Sep 25, 2007 | 03:48 PM
86PACER's Avatar
86PACER
Autozone has both tools. Don't know how different your car is.
The installer tool is the one on the left.
Part Number: 27144
Old Sep 25, 2007 | 04:37 PM
davidf4925's Avatar
davidf4925
thanks for the replies, i'll go to auto zone on friday when I'm off.
To install balancer hub?
