What Would You Do?
Here's the story.
The motor is APART. There is no more exhaust, the heads are off.
I have the stock short block.
Here's the peices I already have:
1. 1.6 Roller Rockers
2. Super Ram
3. Exotic Muscle Headers
The headers have no AIR or EGR fittings.
What I need:
Cam, heads.
Keeping in mind I am keeping the stock short block.
I am assuming there is nothing wrong with the headers or the RRs. That they can be used no matter what I do.
If you had a stock short block to start with, what would you do.
And please, don't give me a list of the most expensive parts ever made. Let's be reasonable. My goal is 325 RWHP on a motor that is "set up" correctly and streetable.
YES, I know I will have to do the torque converter, rear end, and shift kit. That will all come in time. Right now I am simply talking about the MOTOR. Let's keep it simple.
I am staying completely on plan and screw you all......( I'm kidding relax)
I spoke to a local engine builder who uses Brodix heads on many of his builds. I can pay a little extra and have the Brodix heads taken down to 58CC, this way I am giving up nothing on compression. They angle mill both the deck and the intake side.
Cost: $200
So there you have it. The build continues........Parts defined.
The new heads are 180CC ports. The stock heads have 163CC ports.
The justification for the expense of the heads:
1. The cost of porting the existing heads exceeds the price of the new heads. LIngenfelter gets $1600. TPIS gets $1200. Local shop, a few hundred, at least.
2. The flow numbers are 245 on the new heads, 199 on the existing heads. I don't know if I can make up the 46 CFM through porting.
3. I can get $400 for the old heads with valve covers and valve train.
So the heads will cost me $1200 at the end of the day. Not too bad for custom heads.
The valves will be better on the new heads, they will have 5 angle valve jobs and better springs. I would have to do a spring upgrade to the existing heads, that's gonna cost me about $60.
So at the end of the day the delta between new heads and using old heads is about $500, with better, newer components. (springs, valves)
Here's flow numbers for heads..http://users.erols.com/srweiss/tablehdc.htm#Chevy
Are the rockers self-aligning? Since you plan to reuse them, that's a consideration on how the heads will be setup.
What cam are you considering? Planned use of the engine?
I'd definitely go with the Brodix heads.
Jake
Jake
The rockers are self aligning. I have 1.6 RRs, I am not reusing the factory rockers.
RACE ON!!!
RACE ON!!!
The price difference in the heads includes new, better valves, new springs, better valve seats, and a "better" casting.
Is that worth a premium? I think so.
I can't build heads like these for that money. I'd spend say $40 a valve, or $640 extra, just to be even, not to mention the machine shop work. I am assuming I can get a shop to do it locally for a few hundred bucks, I don't even know how realistic it is.
I don't have the time to do it, I barely have the time to do what I'm doing. I'd spend less, but I'd get less too.
I need 58CC chamber, angled plugs, and .560 lift. Those are the specs. Can you point me to a link that I can get that from AFR for $1400?
Thanks.
I remember the thread where he said there were $1400 AFR heads, however, I went through it at that time and I believe that they only came in straight plugs. I need angle.
I am trying to draw on the experience that is here, because there's a lot that's not in the book, and I hope to find it here.
I don't want to do this build again. Once is enough.
I am looking at the Brodix Race Right 180CC heads. I'll have them decked to 58CC.
On the heads I'm putting 1.6 Aluminum Scorpion Roller Rockers.
The cam will be the Accel 74219. It's a 219/219 at 500 providing 560 lift.
The intake will be the Super Ram and matching Accel base.
Exhaust is long tube 1 3/4 headers to an X pipe and dual exhaust out the back.
Finally, a good tune.
What I am looking for is a streetable 325 RWHP car, with lots of torque.
After the engine build I am looking at a Torque Converter and a shift kit.
The rear end is a 307. I know 354s or better would be better, however, I like having the car on the highway and higher gears mean higher RPMs. I'll make that decision after I finish the motor.
Seems that with AFR or Brodix I can't go wrong.
http://www.lingenfelter.com/Merchant...Category_Code=
It is matched to the intake I am using by the guys at Lingenfelter. Since it's sold as a "matched set" I think it should perform well.
Between the intake and the cam I am looking at an "ideal" power bad in the mid rage of 3000-6000 RPMs
