Msd Ignition Mounting??
Old Sep 25, 2007 | 10:37 PM
Brett Richmond's Avatar
Brett Richmond
Default Msd Ignition Mounting??
I have used the search and not found what I was looking which is , How did you mount them it near the fire wall, or did you mount it some where else. I would like to see some pics if possible.
Old Sep 25, 2007 | 10:46 PM
_twisted_'s Avatar
_twisted_
I mounted mine down in the nose by the vapor canister under the dr side headlight
Old Sep 25, 2007 | 11:03 PM
Fubar569's Avatar
Fubar569
mine is on custom plexi sheet mounted above brake booster on drivers side by the cowl...looks good and fits right!
Old Sep 25, 2007 | 11:25 PM
Blownfuel1's Avatar
Blownfuel1
I've installed at least a hundred of these overs the years in our shop, and experienced my fair share of failures till I started mounting them inside the passenger compartment.I know MSD says their waterproof, and I believe them. I also believe that there is trapped moisture in them when their assembled, humidity mostly, and that the more extreme temperature changes their exposed to, the greater the chance of a failure. On my Vette, it's mounted in the right side rear compartment, and it's been in there for almost 10 years without a failure! I'm sure someone will disagree with me, but thats been our experience, so take it for what its worth.
Old Sep 25, 2007 | 11:46 PM
Pete K's Avatar
Pete K
If you have a non power pass seat, there is room under them.
Old Sep 26, 2007 | 04:52 AM
JoBy's Avatar
JoBy
Behind the battery, but it was a tight fit.
http://www.joby.se/corvette/mods/2006-07-01_msd/
To Msd Ignition Mounting??
