Polyurethane conversion?
Old Sep 27, 2007 | 11:38 AM
rickeolis's Avatar
rickeolis
Default Polyurethane conversion?
I'm setting up my C-4 for road-course racing and want to change out all my rubber bushings for polyurethane, and see the kits (F&R) cost less than $300.00, (See www.vbandp.com) but what can I expect for labor charges?
It looks like a big job, has anyone done it or had it done? How many hours for labor?
Thanks-
Old Sep 27, 2007 | 01:00 PM
SCCA VETTE's Avatar
SCCA VETTE
Depends on HOW you do it. If you are able to do so, I would pull the parts off the car and take JUST to parts that have to be pressed out OR cut them out yourself if you can.
If you drop off the car and have them do it all, I would guess 600 bucks (10 hours at 60 bucks a hour) pluss they will have to realign the car after you replace them.
Do you have the ability to do it through the winter little by litte on your own?
Old Sep 27, 2007 | 10:45 PM
johnvette2's Avatar
johnvette2
2nd Gear
I did all mine myself. But you must have access to a press (I used a 5 tone but don't know if a smaller one will work).
The only hard one is the front upper arm. It presses in from the front. I made a support for the aframe since the manual tells you that you can (and probably most certainly) bend the arm without support. My brace was made from 2 pieces of angle that was cut to the exact length of the inside distance between the open part of the frame. That allowed me to press the bushing into the arm without fear of bending the arm together since there is no support.
The sway bar is no treat either, but still pretty easy.
You must remove a couple of the factory metal bushings on the outside of the rubber bushing. It seems that the sway bar uses this extra "shim" bushing as well as a control arm in the rear. They are real soft, just be careful and don't cut the inner part of the control arm.
Good luck/
Old Sep 28, 2007 | 12:00 PM
calpbs's Avatar
calpbs
I did mine as well. I had to make a brace to prevent bending the A frame. I did it along with a total motor and front end rebuild. The suspension bushings were the easier part of of al that. A press is necessary.
Old Sep 28, 2007 | 06:56 PM
rickeolis's Avatar
rickeolis
Thanks guys,
I've put in my own engine, tranny, and more, but this one looks to be too much. I think I'll call around some known Vette shops for an estimate.
-Rick-
Old Sep 28, 2007 | 08:30 PM
aboatguy's Avatar
aboatguy
Originally Posted by rickeolis
Thanks guys,
-Rick-
I believe that installing the engine is harder than changing to poly bushings (I've done both more than once on C4s)
So since you have the skills just break it up into two sections IE do the rear one weekend and then the front the next.
Plan on an alignment on the following Monday.
Mike
Old Sep 28, 2007 | 09:17 PM
5abivt's Avatar
5abivt
Did my whole car about 8 years back. all the polys still look brand new and really made a difference in road feel and handling.
Old Oct 1, 2007 | 01:00 PM
rickeolis's Avatar
rickeolis
Hmmm, it's starting to sound like I should at least give it a shot myself. Either way I need to buy the poly kits.
Guys, I really appreciate it!
-Rick-
Old Oct 1, 2007 | 01:16 PM
SCCA VETTE's Avatar
SCCA VETTE
-Rick-
It sounds like you have some machanical knowledge, I would say go for it. If you do not need the car for awhile, I would go about it by doing one side at a time that way you do not get overwelmed and if you decide that it is not for you you can still take it somewhere to have it done. I would imagine if you get into a situation where you need help that folks on here would be glad to give you any advise to help
Old Oct 1, 2007 | 09:07 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's not hard, just takes a long time since you have to just about remove the entire suspension. For this reason, I would absolutely not pay someone else to do it. Huge labor hours, and they'll probably screw something up on reassembly.
I did it in bits and pieces and combined it with other work.
Old Oct 2, 2007 | 08:56 AM
corvette1989bham's Avatar
corvette1989bham
Do you have a picture of the brace you made OR pictures of you doing this work?
Old Oct 2, 2007 | 12:04 PM
frenchyoliver's Avatar
frenchyoliver
dont you think that having poly bushings is not that good for the car frame ?
As you are loosing the "ruber" flex from stock bushings, the car frame takes much more torsion and flexion constraight that are normaly absorb by stock bushings ?
Old Oct 3, 2007 | 03:21 AM
rodj's Avatar
rodj
With the exception of the top front bushes which need a press can do rest without.Poly bushes are 2 piece , not one piece like original so just squeeze in from each side by hand or with a vise.
Hardest part is getting old bushes out.Have done 2 cars now by using a small drill bit to destroy rubber bush .Can then just knock outer steel liner loose.
In extreme wear cases may not even need to drill bush; will fall apart in your hands , especially bottom rear arm bushes.
If you don't do the batwing bushes can just do rear piece by piece ; one side at a time.No need to dismantle car
Old Oct 3, 2007 | 11:05 AM
rickeolis's Avatar
rickeolis
Talked to the local Corvette specialist here in town and he said roughly $500 for his work plus the price of the bushings, so about $850.00 total, so I think I'll go that route!
-Rick-
Old Oct 3, 2007 | 12:23 PM
jhammons01's Avatar
jhammons01
Ah the easy way!!!
I'd probably do the same.
Old Oct 3, 2007 | 01:30 PM
Ruff Rider's Avatar
Ruff Rider
Hu
Old Oct 4, 2007 | 04:03 AM
Puna's Avatar
Puna
Poly bushing kit thru Summit were less expensive, not a real hard job, just a few bad words, but a press was required, upper A arms were the harders, like another member said drill out the rubber, knock out the steel sleve and presto, out with the old, new are mostlt 2 piece, use LOTS of the supplied lube.
Did my complete suspension, alone, took a few days and like I said just a few bad words.
To Polyurethane conversion?
Old Oct 4, 2007 | 11:03 AM
rickeolis's Avatar
rickeolis
Puna,
Do you recall how many items you changed out? I'm trying to see if I want to go with the Summit kit or the VB&P kit, thanks!
-Rick-
Old Oct 5, 2007 | 02:17 AM
Puna's Avatar
Puna
I dont recall the exact number of items but the kit came with everything except the swaybar and end link bushings.(front and rear)
For the A-arm I just used a rectangular piece of metal bar to keep it from bemding when installing to the rod that slips through the to keep it from bending, nothing fancy.
Hopes this help you out cause I have been helped here and advised many many times and try to give back when I can! I think the summitt kit was about $175.00 or so plus shipping....naturally
Just as a footnote the batwing bushings, I did one side at a time, drilling the rubber was a mus thwen I used a screwdriver/chisel to remove the steel sleve. It can be done, I'm a first timer with vettes but do posses a little mechanical knowledge, if I can do it believe me you can to. Dont forget to let us know how it goes and how much green is left in your pocket after you do it yourself!!!
Old Oct 5, 2007 | 12:14 PM
rickeolis's Avatar
rickeolis
Thanks- I appreciate that!
