C4 to C5 wheel question
Old Sep 28, 2007 | 09:15 PM
Rick84Vette's Avatar
Rick84Vette
Default C4 to C5 wheel question
I have a 1985 coupe with stock 16 inch wheels. I have the chance to buy a complete set of 1999 C5 wheels (17 front and 18 rear). Is this a bolt on swap? I know the bolt pattern is correct but I need to know if any other adapters are required and if so, why? I see a lot of Vette adapters on Ebay.
Thanks for any help.
Old Sep 29, 2007 | 01:41 PM
staugur's Avatar
staugur
The later wheels are a 58mm offset.They will bolt on there but sit inboard about 3/4 inch.To fit correctly you need 36/38mm offset.You can run a 3/4 spacer/adaptor to set them out to where they should be.Beware when you fit the adaptor(3/4) the original wheel studs protrude.Some wheels have a relief between the stud holes and this is not a problem.If not you have to grind the protruding bits down or move up a size in thickness.
