head light brighter replacements
Old Oct 2, 2007 | 02:05 AM
tvetta's Avatar
tvetta
Default head light brighter replacements
The lights are weak, what are my options for brighter clearer head lights at an affordable price?
Old Oct 2, 2007 | 02:42 AM
Demonic85's Avatar
Demonic85
There arent any cheap upgrades for the lighting. You can find minor upgrades by switching to Sylvania Cool Blue's but I hear they're heavy and that cant be good for the motors. The best solution is to upgrade your wiring and convert to HID bulbs or something similar.
Old Oct 2, 2007 | 09:52 AM
runner140*'s Avatar
runner140*
They are not only heavy but if you use them as much a I do, they just don't last.
Old Oct 2, 2007 | 10:43 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Originally Posted by elefkow
They are not only heavy but it you use them as much a I do, they just don't last.
I've had Sylvania Silver Stars in my '96 for 2 years now, and not a single problem. Much brighter than the factory lights. Of course there probably not as bright as the HID conversions, but they didn't cost an arm and a leg either.
Are they heavier than the stock plastic? Of course they are, but who's to say they are "Too Heavy"? Maybe in an early C4 with already worn bushings and/or gears they might be. They don't weigh that much, and the weight is balanced so the headlight motor is not actually pulling the full weight of the light to open.
Oh yeah, I do drive at night so the lights do get used.
Old Oct 2, 2007 | 11:07 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
I recently upgraded to the plastic housings that take those H4? style bulbs. I put Sylvania Silverstars in them. HUGE improvement.
BUT.. after I did some searching on the forum I found out I could have gotten twice as bright lights for the same price
Old Oct 2, 2007 | 05:21 PM
canoeman's Avatar
canoeman
Do tell, what is the twice as bright?
Old Oct 2, 2007 | 06:45 PM
Bubba91's Avatar
Bubba91
Sylvania Silverstars are awesome for the price. I've had mine for about 2.5 years, with no problems. Way brighter than stock.
c4cruiser's Avatar
c4cruiser
The Sylvania SilverStars are probably the best value for the money. Much brighter light and no problems with the stock wiring system. Install the lights and go.
IMHO, the "Cool Blues" do little or nothing to improve lighting. They are not much more than a blue tint on the halogen bulb. You see a blueish tint to the light output but the wattage, lumens, and color temp is not very different from a standard halogen bulb.
The SilberStar lamp housing is somewhat heavier than the OEM-style plastic lamps but as long as the headlight motors and gears are in good condition, you should be OK.
I used the Hella European conversion lamps in my 92 and never had any problems for over 6 years. These lamp assemblies are heavier glass than others and use an H4 bulb. The beam is focused differently and you can get some pretty powerful bulbs that are upwards of 100 watts and 4000 degrees color temps. CIEBE also has conversion lamps for the 6054 type of lamps used on C4's.
True HID lighting would be even better, but expect to pay many hundreds of bucks and do some wiring.
Old Oct 2, 2007 | 06:55 PM
jon0108's Avatar
jon0108
i just installed Sylvania XtraVison headlights on my 86. Brighter than stock, and only $30 for the pair.
Old Oct 2, 2007 | 07:54 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I was contemplating Silverstars, but decided to spend a few more dollars and bought Hella E spec lens's and Hella 100/80 H4 bulbs.
Looks like a 767 is about to land on the road, nope, just me.
Cost me $90 for everything.
Old Oct 2, 2007 | 08:04 PM
cakes751's Avatar
cakes751
I'm running the same setup...love them...much brighter then stock...I paid a similar price...got mine through susquehanna motorsports in pa.
Old Oct 2, 2007 | 08:29 PM
cdnguyred88's Avatar
cdnguyred88
I've been running this set up for almost 9 years if not longer. No problems at all in my '88.
Old Oct 2, 2007 | 08:30 PM
tlong's Avatar
tlong
Hella yeah
Old Oct 2, 2007 | 09:56 PM
tvetta's Avatar
tvetta
Where can you buy these SilverStars?
Old Oct 3, 2007 | 09:51 AM
cdnguyred88
I would guess NAPA, Pepboys or most large auto parts stores. I know in Canada they are availble at Canadian Tire.
Old Oct 3, 2007 | 10:02 AM
wro87's Avatar
wro87
Went with Hella and Cibie' 130/100w H4 bulbslong time ago no problems at all with wiring or the alternator and can see way down the road . After 20yrs now just fianally burnt a low beam out, guess I will have to by a couple of bulbs. If one goes the other will go later. Now if i could find some way to put 100watters in the fog lights?
wro87
To head light brighter replacements
