Fuel Injector Question
Old Oct 2, 2007 | 06:46 PM
TON12350's Avatar
TON12350
Default Fuel Injector Question
Will ford racing injectors work as direct replacements for a 1995 vette? Is there any you have to do to get them to fit, or is everything the same? The o-rings, retainers, harness, etc. Attached is a link to the injectors I was looking at.
Ps. What happened to racetronix, they only have 25 or 32 lb injectors.
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 2, 2007 | 07:38 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
The flow rate looks to high for a stock LT1.
Old Oct 2, 2007 | 11:19 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
This is the exact injector Delphi carries as as replacement for your 1994 LT1 injector:
http://www.racetronix.com/621050.html
Old Oct 3, 2007 | 08:49 PM
jeffyc's Avatar
jeffyc
the injectors should fit
i have them on my 383 l98
i dont know what the flow is needed buy a lt1 but for some reason i think a stock lt1 has #24 stock
so if u get these injectors you might need your ecm reprogramed
Old Oct 4, 2007 | 12:31 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
No recal required. The dynamic flowset is inline with the factory injector. That is why Delphi lists it as a direct replacement.
Old Oct 4, 2007 | 01:14 AM
finally_got_it's Avatar
finally_got_it
i just installed the ford 24rlb injectors in my 95 yesterday no problems they work great
Old Oct 4, 2007 | 09:59 PM
TON12350's Avatar
TON12350
Sorry, I forgot to mention the car is not stock, in fact it is running a bit lean and I am going to get it tuned. Most likely I will need larger injectors. I have #24's right now, so I am looking for #28 to #30 plug and play type replacements. Does racetronix have either size?
Old Oct 4, 2007 | 10:06 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Yes, we have a bunch of choices listed on our web page.
We will have some new LS1 injectors listed there tonight as well.
Old Oct 8, 2007 | 09:50 PM
TON12350's Avatar
TON12350
I went to your website and I don't see any delphi 26's, 28's, or 30's pound injectors. Do you still sell them?
Old Oct 9, 2007 | 08:41 PM
TON12350's Avatar
TON12350
When will the racetronix website have the 26#, 28# and 30# delphi injectors??
Old Oct 10, 2007 | 12:17 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
They are all there on our site.
Keep in mind when you are comparing Ford/Bosch SVO injectors to Delphi injectors you must factor in that Ford rates their injectors at 39PSI and Delphi rates them at the industry standard 43.5PSI. In other words a Delphi 32 is really the same as a SVO 30. Some ads quote the flow with test solvent which is usually n-Heptane. When converting to gas from n-Heptane multiply the flow rating by 1.035.
To Fuel Injector Question
