Head Retorque After Running Engine
Old Oct 3, 2007 | 12:52 PM
90Indy's Avatar
90Indy
Default Head Retorque After Running Engine
As some of you may remember, I recently lost a head gasket due to my lack of "cycling" the new head bolts and not retorqueing the heads after running the engine. I have now finished the head gasket replacement and have run the engine through several heat cycles and everything appears to be good. I think I am now ready to disassemble for the final torque.
Before I begin the disassembly is running the engine through several heat/cooling cycles, basically at idle, good enough? Is there any reason to put the car on the road?
I don't dislike working on my car, I do however dislike doing things over. Any thoughts would be appreciated.
90Indy
Old Oct 3, 2007 | 02:03 PM
SunCr's Avatar
SunCr
Design and specs are a one time deal and the only thing more twist is going to do is ruin the sealant on the head bolt threads. Assuming you had the typical leak at #7, you need to make sure it didn't wear a groove between the coolant passageway and the cylinder and you want to make sure the deck is square and that the heads aren't warped. Otherwise, following the correct torque sequence and values the first time should keep it leak free.
Old Oct 3, 2007 | 03:32 PM
90Indy's Avatar
90Indy
I had a leak at #3 cylinder. I have installed new AFR heads (didn't like the #'s from my reworked 113's) and I am running an 8 psi blower. The old head gasket had burned through areas where the exhaust gas had gotten between the head and the block. I thought I did everything correctly in the first install but something went wrong. The reworked 113's were on the car for 2 years/5000 miles when I added the blower. I did not drive the car with the blower and even trailered it to have it dyno tuned. The water leak started right after the dyno.
I don't mind torqueing the heads again, I just want to make sure I am getting the most bang for the buck.
90Indy
Old Oct 3, 2007 | 04:05 PM
Demonic85's Avatar
Demonic85
I used brand new ARP bolts which I guess also prevent them from backing out or some crap cause I went to retorque them down and they were still at 65 ft lbs.
Old Oct 3, 2007 | 04:46 PM
LD85's Avatar
LD85
I have always done one heat cycle
Get it up to full oil and water temp & let it run for 20-30 minutes,
shut it off for a full cool down,, all the way to cold, like the next morning,
then re-TQ sequentially to spec
Old Oct 4, 2007 | 09:33 AM
Aardwolf's Avatar
Aardwolf
All the times I have checked to retorque one or two of the bolts/studs just barely moved. What does the gasket maker say to do?
Old Oct 4, 2007 | 11:13 AM
85vet's Avatar
85vet
Cruise-In V Veteran
If they are NEW - retorque, not really necessary if heads are seasoned. Don't ask me how I know
Old Oct 4, 2007 | 11:29 AM
rick lambert's Avatar
rick lambert
, that's the way I was taught and I never ran into a problem. But alot of guys here agree with SunCr, discussion has come up several times with mixed responses.
Old Oct 4, 2007 | 11:48 AM
Vito.A's Avatar
Vito.A
Most of the new Fel Pro head gaskets do not require a re-torque, but a lot of us do it anyway. I am not sure what Cometic recommends, but we always retorque them.
The idea to this is not that the bolts have backed out, but that the heat expansion of the head has crushed the gasket slightly. The bolts require a certain amount of stretch to maintain the pre-load crush on the gasket. A re-torque after it has been thoroughly heat cycled insures this stretch pre-load is maintained.
Usually the culprit in head gasket problems is a surface that is slightly warped, or a lean mixture condition.
Old Oct 4, 2007 | 06:24 PM
waveman22's Avatar
waveman22
Do it correct the first time & leave it alone. Use ARP bolts & be done with
it once is enough.
Waveman22
Old Oct 4, 2007 | 07:57 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ive never had to retorque heads, think the mfr prints it on the pkg...I did double check twice and all was well. your results may vary though.
On a copper head gasket I definitely would fwiw.
Old Oct 4, 2007 | 10:44 PM
90Indy's Avatar
90Indy
I guess it basically comes down to what you are most comfortable with. The ARP bolts were "cycled" 5 times before the final torque which is what ARP recommends. The AFR Eliminator heads are new and if I remember correctly AFR recommends a retorque while Fel-Pro does not.
Since replacing head gaskets is a real PITA in my opinion, I will take the time to retorque the heads. Doing this project a third time would not be good for my marriage in the near term.
Thanks for replies.
90Indy
Old Oct 5, 2007 | 05:50 AM
thirdtimevetteowner's Avatar
thirdtimevetteowner
You never mentioned which gasket you used (shim, composite, thickness). Just curious since I am doing a head R & R this winter with the same heads.
Rich K
Old Oct 5, 2007 | 07:45 AM
chucks88's Avatar
chucks88
This story sounds hauntingly familiar...
http://forums.corvetteforum.com/show....php?t=1785319
At any rate....after cleaning up the above mess my process of "rolling-in" my new ARP bolts consisted of torquing the bolts down and letting them sit over night for 5 straight nights. I let my final torque sit for a week while I was on vacation and checked them again when I returned and dropped my intake base back on the motor.
I went through about a 1/2 dozen(50 miles or so)heat cycles before I checked the bolts. I checked all the bolts I could reach without dropping the exhaust or removing my rocker arms....non of them budged so I buttoned it back up
To Head Retorque After Running Engine
