Underhood lights
Old Oct 3, 2007 | 10:48 PM
Rick84Vette's Avatar
Rick84Vette
Default Underhood lights
Dumb question by C4 newbie. What controls the underhood lights? Is there a switch somewhere to turn them on or off? Mine don't come on and I traced the wires down the hood into a connector but see no switch? ???
Old Oct 3, 2007 | 11:33 PM
Dads90's Avatar
Dads90
Correct me guys if I'm wrong but I think they have a mercury switch, when the hood is popped they come on. I put a small roll switch (lowes or home depot, lamp type switch) on the wire to turn off when the hood is up for long periods. If they not coming on it could be a fuse.
Old Oct 3, 2007 | 11:49 PM
John A. Marker's Avatar
John A. Marker
They are on a mercury switch . You should be able to see a small glass tube with mercury in the tube. When the hood is up the mercury runs to the other side of the tube and makes the electrical connection and turns on the lights. Are you sure the bulbs are good? Some members have installed a inline switch to be able to turn the lights off when the hood is up for long periods.
Old Oct 4, 2007 | 12:07 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
lights controlled by mercury switch, if they are not working its a couple of things:
1. unplugged
2. blown fuze
3. light burned out
The roller switch works great, have them installed on mine, cheap and easy.
Old Oct 4, 2007 | 04:45 AM
Da Mail Man's Avatar
Da Mail Man
.....there was a post on this w/in the last 5 days or so.......do a search!
Old Oct 4, 2007 | 08:39 AM
kalister1's Avatar
kalister1
On my 93 there is a fuse holder inside a cover, down behind the drivers headlight. If you followed the wires down, maybe that is the fuse holder you traced it to?
To Underhood lights
