freakin car again!
Old Oct 4, 2007 | 12:45 AM
all show and more go's Avatar
Default freakin car again!
ok, im going to get straight to it, i own a 86 4+3, as some might remember i was changin the main seal and after i did so i put full synthetic in it and the prob. im having is that when i get on it the rpm's will go to about 3400 rpm then slowly drop, i think it might be a fuel issue but im getting some lifter sounds too, not bad sounds, they just sound louder then they use too and my clutch is slipping and the peddle engages the clutch further out,does anyone have a clue what's goin on? these prob. became more evedent after i took it on the highway for the first time on a 50 mile trip!
p.s: this is what the alphabet would look like if Q and R never exsisted!( little humor)
Old Oct 4, 2007 | 02:03 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Sounds like a bunch of different issues:
Fuel pressure: tape a fuel pressure gauge onto the window and take it for a drive and do readings.
Clutch: sounds like the MC is going south...slipping & engaging
* Any oil leakage? check the plate for oil
Old Oct 4, 2007 | 02:26 AM
jhammons01's Avatar
jhammons01
did you get in there and not change the clutch while you were doing the RR main seal?? That may have been a mistake.
I know when my pedal dropped, the clutch was done.
Old Oct 4, 2007 | 05:37 AM
Da Mail Man's Avatar
Da Mail Man
.....could be a fuel pressure problem but, sounding more like a clogged cat....
Old Oct 4, 2007 | 08:59 AM
rick lambert's Avatar
rick lambert
Separate issues, but it sounds more like a fuel delivery problem to me as far as the motor.
Old Oct 4, 2007 | 10:20 AM
Da Mail Man
......could not a partially clogged cat cause the sluggishness?
Old Oct 4, 2007 | 11:06 AM
i fully built the motor at a machine shop,and put a new clutch in!
Old Oct 4, 2007 | 11:07 AM
i dont have a main cat anymore! still have the 2 little ones thou!
Old Oct 4, 2007 | 01:34 PM
Da Mail Man
.....ohhh, i didn't see that in your initial post as it was not mentioned..
Old Oct 4, 2007 | 05:50 PM
scott85vette's Avatar
scott85vette
Did the problem exist before the seal job?Was the flywheel machined?
To freakin car again!
