data master code
Old Oct 4, 2007 | 08:52 PM
vett40's Avatar
vett40
Default data master code
hello everyone
newbee here been reading forums for a while. i think they have great information time to ask for help
i have a 93 ruby lt1 i have downloaded datamaster have the cable
i know you have 20 times to use it for free i try to use it yesterday plug it in to my lap top first thing it asked for was a code didn't know what to do can any body help
Old Oct 4, 2007 | 09:13 PM
sonomacrew01's Avatar
sonomacrew01
I don't know how many times you've actually "used it" but just opening the program is considered a use. I don't think that anyone who has datamaster can give you their code and it will work for you.. Give datamaster or http://www.aldlcable.com/ a call for the registered authorization code...
Old Oct 6, 2007 | 09:25 AM
Casethecorvetteman's Avatar
Casethecorvetteman
No, opening the program is not considered one of the 20 free trials. Opening the "Record ALDL Data" is considered 1 use, and as long as it stays open, you can log as many times as you like on that 1 use.
Old Oct 7, 2007 | 09:07 PM
corvette1989bham's Avatar
corvette1989bham
not to threadjack but does datamaster work on the hybrid (95-96)OBD1/OBD2 corvette systems...they have the obd2 port on the car.
Old Oct 8, 2007 | 03:53 AM
Casethecorvetteman
94 and 95 are NOT OBD2, they are both the same and both full OBD1. Datamaster WILL work with both of them. I know, cause i use it and have done on both. They DONT have an OBD2 port on the car, they have a 16 pin ALDL connector.
96 are not hybrid systems, they are full OBD2.
Old Oct 21, 2007 | 06:01 PM
BlackC6LS3's Avatar
BlackC6LS3
It is a great program, but you will have to fork out the cash and get an authorization code that will only work on your computer.
Old Oct 24, 2007 | 01:22 AM
Arkybill's Avatar
Arkybill
I've got a 94 LT1 and have been using the Datamaster program. Case is correct in that just opening the program does NOT count as a "use" in the 1st 20 times. Also, you can just run the program (as long as you don't LOG-it doesn't count).
It's pretty good. I've been lurking here for about a year and haven't had enuf sense to understand WTF is going on. Just get datamaster and go from there, you can't go wrong. And you WILL learn a lot!
bill
To data master code
