High idle while shifting and stop
Old Oct 4, 2007 | 09:02 PM
bruced267's Avatar
bruced267
Default High idle while shifting and stop
I finally have the car running, back story I was chasing a hunting idle I found a intake leak and a few more on top of that. Set min idle speed and tps voltage and it seems good , BUT the idle is very slow to come down while shifting or full stop. If I rev the engine it will fall quicker but not correct. Yes the iac is clean, throttle shaft is not worn rebuilt 52mm, base timing is 8btd, yes I have a vss not sure which one. Street & performance made my harness and sold me the rest. Where do I start to look ?
