Brake pads????
Old Oct 5, 2007 | 08:35 PM
sknight88's Avatar
sknight88
Default Brake pads????
Ok, havent gotten down "below" yet, but will be soon. While at the Chevy dealer, I had them pull up pads and rotors. 264.00 for front brake pads! The rotors were about half that. So I jumped over to Napa online. Cheapies are 24.00 bucks and most are about 125.00. so, of course, not getting the cheap ones, car brakes bad enough as it is, but whats the general group feeling for pads and even rotos for the C4, mines a 89. Thanks, Shawn
Old Oct 5, 2007 | 09:09 PM
c4cruiser's Avatar
c4cruiser
Are you just looking for stock-style replacements? If so, the NAPA rotors will work just fine. Brembo makes a good stock replacement rotor (made in Canada) and Tire Rack has them for about $55 each.
For pads, go with something like Raybestos QuietStop pads which are ceramic and will not generate much dust at all. The NAPA pads are made by Raybestos. Their semi-metallic pads are also good but expect some dusting.
If you want improved stopping power and don't mind a little brake dust, then check out the Hawk HPS pads. Excellent bite when cold and will work for autocross too. AC Delco pads are good quality for street use and I think they are also made by Raybestos.
Performance Friction make some good pads too. You should be able to find them at Shucks/Kragens. The "Z-rated" pads are a good performance pad for the street and some autocross/track day work.
Old Oct 5, 2007 | 09:19 PM
Eakster's Avatar
Eakster
I used the ceramic pads from NAPA. Work really well on my Ford Escape, much better than stock, not such a big improvement with these pads on the vette, but still do the job. Not bad for 80 bucks a set.
Not changed rotors, just had them resurfaced - they weren't too bad ('96 with J55). I don't rate my vette's brakes very highly, except at high speeds, I don't think the pads are to blame.
Old Oct 5, 2007 | 10:35 PM
Louis Bartay's Avatar
Louis Bartay
Default Pads
I tried Auto Zones best pads on my J-55 96 and the only difference was when I tried to slow down fast from high speeds and the the GM stock pads were much better. I now have Hawk HPS pads and they stop better than then the GM pads ( less high speed brake fade). You pay for what you want. Drive slow and cheap pads are safe.
Old Oct 5, 2007 | 10:49 PM
gbody5's Avatar
gbody5
Go to www.rockauto.com
Select the AC Delco pads of your choice
End of story
Oh, and here is a code for 5% discount, good through Nov 27.
Your discount code is:
781883646793
Here's how to use it:
* Enter your code in the "How did you hear about us" line of the shopping cart.
* If you are using our traditional HTML catalog, please click the "Set"
button to the right of the field.
* Your discount will automatically appear, subtracted from your order total.
Old Oct 6, 2007 | 02:25 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
If you enjoy driving a Real Corvette, spend the money and buy the Hawk HPS pads. Amazing difference.
Old Oct 6, 2007 | 02:44 PM
runner140*'s Avatar
runner140*
Old Oct 6, 2007 | 07:46 PM
Ajaste's Avatar
Ajaste
I'd give a dealer $264. for front pads when he sucks it out of my ****. I installed Performance Friction pads on all 4 corners of my 96 LT-4 last month and am very happy with em.
Old Oct 7, 2007 | 02:53 AM
fixit's Avatar
fixit
I thought the Performance Friction pads I installed on my '94 were no better, in fact worse when cold, than stock AC Delco.
Old Oct 7, 2007 | 07:48 AM
sknight88's Avatar
sknight88
Thanks everyone
Old Oct 7, 2007 | 07:54 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Upgrade to J55 13" brakes in the front. Try NAPA for the rotors. Get good quality pads, Hawke pads are good. The Napa guys can look up the parts you need.
To Brake pads????
