Oil Catch Can...
Old Oct 6, 2007 | 05:47 AM
Lars87's Avatar
Lars87
Default Oil Catch Can...
I have done about 10 trckdays this summer, and evertime I have used about 1 qt of oil...undre normal use the car dosent use any oil, so this must be fumes etc from hard "red line" use. So i got to think that meybe next year is should use a oil catch tank/can..
has anybody here installed one?
which one to get?
where is a good places to install it in the engine bay?
Old Oct 6, 2007 | 01:25 PM
KeyWestJack's Avatar
KeyWestJack
Old Oct 6, 2007 | 01:47 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I used this guys (Dave 68 on the forums post), as it is a real coalexcing filter for seperating oil, and due to my low tension rings I need one, and it works.
http://www.conceptualpolymer.com/PCV...oval%20101.pdf
http://forums.corvetteforum.com/show...=oil+catch+can
Old Oct 6, 2007 | 11:55 PM
GRX's Avatar
GRX
I got one from Greddy but have yet to install it. Better to install it in a cool spot....
Old Oct 7, 2007 | 01:09 AM
emo-vet's Avatar
emo-vet
hi guys,
just wandering do you still need to run a oil catch can mod if you have a filter vent already installed on each valve cover please ?
thanks
shae
Old Oct 7, 2007 | 01:27 AM
sami85L98's Avatar
sami85L98
Originally Posted by emo-vet
hi guys,
thanks
shae
U dont have to, its a option. I did that in past did not helped, catch can is the best way, atleast to me, may be those vents on VC's will help on stroker's but i dont think on stock motors.
Old Oct 7, 2007 | 01:28 PM
steve40th's Avatar
steve40th
I installed mine here. Routed the lines down the passenger side AC lines to the firewall and through the back of the manifold/EGR area to the pcv connections.
Old Oct 7, 2007 | 02:59 PM
93 ragtop's Avatar
93 ragtop
Hey Steve, do you have two seperators? It looks like a husky inline and the watts by the radiator. Also, are you using stock valve covers and what breathers are you using?
Old Oct 7, 2007 | 10:57 PM
steve40th's Avatar
steve40th
Yes I have two seperators. The HOme Depot Ghetto version really is a water seperator, but works pretty well. I did it because I wanted to eliminate oil (for a visual )before the watts.
Great service from Dave and very high quality product.
I am using stock valve covers, with one breather as I have the DELTEQ on the other vale cover.
To Oil Catch Can...
