Electric Water Pump
Old Oct 6, 2007 | 04:22 PM
TPI BOY's Avatar
TPI BOY
Default Electric Water Pump
who has one and what do you think
Old Oct 6, 2007 | 06:24 PM
derekguzz's Avatar
derekguzz
my buddie has one on his 96 Trans Am. and its awsome. his temps barley go over 160 when its on. its wired to a switch. he has an LT1 also.
Old Oct 6, 2007 | 07:16 PM
emo-vet's Avatar
emo-vet
i have a csr brand electric pump on my 1991 L98 vette that i succesfully modded and fitted ok just recently,took some work,removing certain parts.
but yeah its all good.
cheers
shae
Old Oct 7, 2007 | 12:02 PM
TPI BOY's Avatar
TPI BOY
Anyone else have one, if so what do
you think good or bad
Old Oct 7, 2007 | 12:11 PM
Hotred94's Avatar
Hotred94
There are several advantages to an electric wp; removes a source of leakage above the opti, good for about 5-7 hp, constant flow regardless of engine rpm, ability to run wp with engine off for cool downs and rad flushes.
Old Oct 7, 2007 | 12:22 PM
aboatguy's Avatar
aboatguy
I have the Meziere HD and it has given me no drama!
Old Oct 7, 2007 | 01:10 PM
TPI BOY's Avatar
TPI BOY
Do you notice that it runs cooler or cools faster
Old Oct 7, 2007 | 03:46 PM
Terrible Juan's Avatar
Terrible Juan
I bought a Summit Racing electric water pump. My temps rarely go above 200* now. It's a really nice unit and even comes with a new o-ring for the water pump (you have to buy a new o-ring from the dealer with most other electric water pumps). Only thing I bought extra was a Painless relay kit.
Old Oct 7, 2007 | 09:27 PM
TPI BOY's Avatar
TPI BOY
Do you guys run a heater if so how do you
hook it up
Old Oct 7, 2007 | 10:25 PM
MTVette's Avatar
MTVette
I had a Meziere water pump installed into my 92 LT1 this year, and took at least two tenths of a second off my quarter mile time, which is a pretty good improvement. It cools down from 180 immediately after a run to under 130 in about 10 minutes. I also run a fan switch. I found that this setup drained the battery too fast, so I also put in an Optima Red Top to handle the current drain.
Old Oct 8, 2007 | 05:55 AM
derekguzz's Avatar
derekguzz
how much for a normal costing unit. im wondering if i should switch over..
Old Oct 8, 2007 | 11:15 AM
rickneworleansla's Avatar
rickneworleansla
Is that part #50106 for the wiring harness? I have not installed my Meziere HD yet. It's still sitting in a box at home.
http://www.painlessperformance.com/M...nstruction.pdf
Old Oct 8, 2007 | 03:58 PM
TPI BOY's Avatar
TPI BOY
hook it up
I should have said plum it up. I don't
see any inlet or outlets for the heater hose
Old Oct 8, 2007 | 07:34 PM
Strick's Avatar
Strick
Hey guys, lets talk LT1 and L98s separately. It could get confusing.
Old Oct 8, 2007 | 08:04 PM
TPI BOY's Avatar
TPI BOY
Ok lets talk L98 tpi
Old Oct 8, 2007 | 09:37 PM
derekguzz's Avatar
derekguzz
for the lt1, could i use the same water pump i have and just wire a switch.?
Old Oct 9, 2007 | 02:36 AM
emo-vet's Avatar
emo-vet
hi again guys,
the earler csr e/water pumps didnt come with a heater pipe inlet.
but the tech guy @ csr said you can just drill and tap into the elbow side which i did to install on my 1991 L98 vette
no worries
cheers
shae
Old Oct 9, 2007 | 10:30 AM
Strick's Avatar
Strick
Maybe I missed something here. Which water pump do you have installed? Cam driven or electric?
Old Oct 9, 2007 | 04:22 PM
TPI BOY's Avatar
TPI BOY
For the tpi do you run the 55 gallon or the 35 gallon
To Electric Water Pump
