Can this work?
Old Oct 8, 2007 | 03:49 PM
BlackVette00's Avatar
BlackVette00
Default Can this work?
Can you put a Powerdyne Supercharger from a camaro LT1 into a corvette LT1? like the kit? if not, can you modify it to make it fit?
Old Oct 8, 2007 | 05:05 PM
mn_vette's Avatar
mn_vette
I don't think so. The Camaro one spins one way and the Corvette one spins the other way. It has to do with the belt routing and the sc placement.
Old Oct 8, 2007 | 05:09 PM
qwiketz's Avatar
qwiketz
in the end it wouldn't be worth it even if you could. I'd buy a kit made for the lt1. It'll cost you less in the long run.
Old Oct 8, 2007 | 10:46 PM
BlackVette00
how about a powerdyne kit from a pontiac LT1?
Old Oct 9, 2007 | 02:21 AM
qwiketz's Avatar
qwiketz
The only possible way would be to modify or redesign a carroll supercharging bracket (blowerworks.net). I don't even know how realistic that is.
If you want a challenge, you've got one there. My vortech ysi setup isn't as much of a challenge as this idea and I still had to fabricate and modify stuff.
Old Oct 9, 2007 | 07:02 PM
hgh pwr's Avatar
hgh pwr
camaro or firebird is going to be the same,like quick said will cost more in the long run,plus the powerdyne only has 4to5 lbs boost so its not really worth it,just MHO.
To Can this work?
