Long story short....
Wife took my 85 Vette out...heard a loud noise...turned around and headed home...car was very hard to steer and smoking...( her words ) drove it about 15 miles then it went dead at a stop sign and would not start...turns out the Accessory belt broke....I replaced that and now the car runs really rough...will not idle and smokes white smoke from the exhaust....it ran like a dream before this happened...am I totally screwed or is there something else I need to do.....Please help me out....
Sounds like the serpentine belt broke, when the belt goes the waterpump on the L98 cars quits pumping and the power stering pump quits working too. They are both belt driven. The white smoke sounds like it got really hot because she kept driing it and it popped a head gasket. Check your oil for coolant. Look at the bright side if she popped a head gasket now is the perfect time for a heads and cam swap.
.....sounds like coolant in the combustion chambers.......also check your oil.....had a car one time that after if ran for a bit would smoke like all hell..tore it down to trash the engine and took the head off and found a dime sized hole in the top of the piston...
Hopefully she did not drive it enough to overheat the motor severly though.
Def sounds like a head gasket. be careful trying to start it though for checking things out. Coolant can leak into the cylinder while at rest and hydrolock the motor. If you try to start it, REALLY bad things can happen.
Remove the plugs and hit the starter, that will squirt any coolant out of the sp. plug hole.
Good luck and if nothing else, find a set of late C4 alum heads. These should be reasonably priced. The 85 heads are terrible and I could not imagine putting them back on.
She drove it until it stopped. You would be the luckiest man in the world if all it needs is a head gasket or two. That baby got cooked. I would be reluctant to use THAT as a core, depending on what you find on the tear down.
Look on the bright side, time to do that upgrade that you've been thinking about and you can blame it on the spouse. Not that you will actually say those words of course.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If women are allowed to have drivers licenses, the dummy lights should be redesigned to pull their hair and slap them when oil pressure or coolant temp is out of spec.
Obviously the single, big, red light on the dashboard wasn't clear enough for here.
My dad put 280,000 mi on his Suburban on the original engine. Sold it to a friend and within 2 weeks the friends wife destroyed it driving without oil pressure.
From: One day you're a Comet...the next day you're dust... Arkansas
Yep......this is the screwing you get for the screwing you got. You deserve half the blame for letting a woman drive an old car.
That is the best idea I've ever heard. The sad part is after a woman kills a car she blames the car or the guy that owns it.
How long was the drive home? Hiway? Side roads? Idle time?
Sounds like the head gaskets are gonners, but there's a chance the heads themselves are damaged.
Thanks for all the replies. I am leaning toward a blown head gasket. She drove the car approx 15 miles mostly highway and said she drove normal speeds ( 60 -70 ) then when she turned off the highway into our neighborhood it went dead at the first stop sign.
60-70 MPH for 15 miles without coolant flow after it is already at operating temp! Did the motor crank at all or slow when it died?
