Which window motor do I have
Old Oct 9, 2007 | 02:19 PM
teufelhund's Avatar
teufelhund
Default Which window motor do I have
I have an 86E auto with iron heads... I know they have both window motors for 86 and need to replace the drivers side. Anyone know which motor I need and what the part number is for it.... Thank you it is greatly appreciated.
CPL USMC
Old Oct 9, 2007 | 02:23 PM
Demonic85's Avatar
Demonic85
I dont know what the part # is, but its the one that uses the plastic strip to raise and lower the window... i'll look it up.
Cant find an OEM part # but the one your looking for is at the bottom of this page. http://www.mamotorworks.com/corvette?frame=3.968
Part # 614-338
Old Oct 9, 2007 | 02:25 PM
teufelhund's Avatar
teufelhund
Thanks so is it the same as the one for an 85???
Old Oct 9, 2007 | 02:33 PM
jon0108's Avatar
jon0108
i just did mine on my 86E. Its the one for an 85. Of course i got the wrong one and thankfully, when i went back to the auto parts store after taking the old motors out the parts guy had them in stock. Just check to see if you have the white regulator ribbon
Old Oct 9, 2007 | 02:40 PM
teufelhund's Avatar
teufelhund
Thank you gentlemen
Old Oct 9, 2007 | 03:52 PM
staugur's Avatar
staugur
Are you sure the motor is defunct or maybe just a broken ribbon?Put your ear to the door and hit the switch.Any noise and the motor is probably OK>
To Which window motor do I have
