Couple Questions
Alright, the first question I have is: are there any carbon fiber panels for the interior of the 84 style interior? I've done a little searching, but there only seems to be for the later style C4, C5, and the C6. The main piece I would be wanting would be the top of the dash, since it is cracked all to hell. Other pieces would be cool, but if all else fails I could make most of them myself.
Question number two: I have the auto. I want a manual transmission, but I don't want the 4+3 (if I don't know how it works, I don't want it...
). Besides, the daily driver shouldn't have a manual while the weekend car has an auto... So I was looking at the 6 speed manual transmissions. Will the transmission bolt directly up to the engine? I'm sure that I would need a different driveshaft. I'm assuming the 6 speed would be a good match, but I don't know if it will bolt up to the D36 differential.Which brings me to question number three: what is the power potential of the D36? Mine was rebuilt before I bought the car so I'm not too worried about it wearing out through daily driving. But I've run 350hp, 500hp, and now 400hp through it, and I admit that I run it pretty hard. Seeing as it was meant to be run in a car with 205hp, I've become worried about how long it will last. So I was looking in the OEM market for a replacement. Seeing as my goal is eventually to have 950whp, are the OEM diffs even worth considering? Is there a certain aftermarket company I should be looking at?
Question number four: hoods. I've seen huge cowls and the like, but does any company make a simple OEM style lightweight hood for the C4? The stock piece is very heavy so weight reduction there would make me happy. It would also make the hood easier to open (WHY is the prop on the other side of the car again?). Again, I don't want some radical thing, just something I can paint and will go unnoticed. Or am I just going to have to get out the aluminum sheeting and start cutting and welding?
Thanks for any help in advance. And sorry if my questions have been answered a million times before, I don't have much time to search the site.
As for the tranny, I have done some reading and I have seen that there are several transmissions used over the years that the C4 was made. Several different engines too. I know that most are based off the same block and therefore should have the same bellhousing. But I'd kind of like to know for sure.
I'm sorry that after being a member of the forum 3 days that I haven't searched the entire thing and don't know the answers to my questions.
But your best friend here is to learn to use the Search function on the main menu bar:
Search, Advanced, Include Archive Posts, Pic C4 section (general or Tech) and search... all your question have prop been covered to some degree in the archive posts... I've found 70% of my question and addl info going this route, then when you do as a specific question you'll get good responses.
Blow off the 3 month newbee answer... Research and have fun
But I guess it all ends in a search anyways... But I still can't find a thread about CF interior pieces for my interior:
They all seem to be for the later "wrap around cockpit" style. Which is why I asked. The search: http://forums.corvetteforum.com/sear...archid=6306421
As for the diff... http://forums.corvetteforum.com/sear...archid=6306468
http://forums.corvetteforum.com/sear...archid=6306478
And the word "the" really screws up the results...
http://forums.corvetteforum.com/show...ial+of+the+D36Now as for the transmission... I was going to ask instead of running a search for every tranny type. And then finding out which can be built for my power goals. I'll search later.
Check out Richmond Gear which makes a solid 5 speed transmission which is (generally) a direct replavement for the Doug Nash 4+3 tranny.
