High Oil Temp - Help ASAP
Old Oct 11, 2007 | 09:08 AM
ronman327's Avatar
ronman327
Default High Oil Temp - Help ASAP
High oil temp of 230 F after 8 hours of driving at 60-65 mph. Do I need to be concerned? Need help ASAP because I am driving another 20 hours in 3 days. 113,000 miles; using Castrol 20/50; 87 'vette
Any suggestions would be greatly appreciated.
Old Oct 11, 2007 | 09:14 AM
Chatman's Avatar
Chatman
That isn't high at all. Why are you concerned? It suggests a coolant temp of about 210. Is your coolant running much less than 210?
Old Oct 11, 2007 | 09:48 AM
Muffin's Avatar
Muffin
Oil temp should be slightly higher than coolant temp. Yours is if your coolant is running 210 or so. Why 20/50 oil? That is on the heavy side with 10/30 or 5/30 being the norm.
Old Oct 11, 2007 | 10:48 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
What was the outside temp during your 8 hour drive?
Did you check under the front of the car/in front of the Radiator for leaves/bags/etc?
How many miles on car since oil was changed?
what was the average oil pressure during the drive (s/b 60+/-)?
What brand oil filter (as some (mobil-1) allow more oil to flow and the oil to stay cooler and others (fram ph... ) are crap and leak dirty oil ?
How clean is the bottom of the oil pan (i.e. oil leaks?)?
Which Castrol are you using, GTX(dino) or SYNTEC (synthetic)?
suggest updating your profile and putting a location (and like mine the car year/model in the location field)...
Old Oct 11, 2007 | 01:48 PM
ronman327's Avatar
ronman327
Underbelly is clean. Water temp running 160-180. Outside temp was 80 when I noticed the high oil temp. 500 miles since last oil change. Using Purolator oil filter. Castrol GTX oil. Average oil pressure was 60+ when doing 67 mph. Oil is still clean - not dirty. What do I need to do in order to change to Mobil-1 synthetic and Mobil-1 oil? High oil temp started when I was stuck in traffic at 5 mph for 20 minutes - but then it didn't want to cool back down. Before I was stuck in traffic, the oil temp was running about 210.
Old Oct 11, 2007 | 02:14 PM
JAKE's Avatar
JAKE
230 F isn't "high oil temp"; not at all and there's no need to worry about it.
I've often thought one of the reasons car makers put 'idiot' lights in so many models is that 'numbers' cause unnecessary concern. Wish I had a dollar for every post I've read about temperature/pressure numbers.
Enjoy the drive; forgetting about the 230* F oil temp will make that easier.
Jake
Old Oct 11, 2007 | 02:23 PM
CFI-EFI's Avatar
CFI-EFI
Jake
The only numbers I see to be concerned about are "Water temp running 160-180.". Too cold. That will make frequent oil changes a necessity.
RACE ON!!!
Old Oct 11, 2007 | 05:38 PM
theadmiral94
with CFI-EFI, water temp is low, you probably have a 160 thermostat, but with your oil temps getting up to 210+, some of the oil concern is lessened, but during colder periods, CFI-EFI is dead on.
With over 100k miles on your car, changing to Mobil-1 Synthetic could be problematic (i.e. leaks, clogged oil passageways) as synthetics work so well because they leave less deposits and have more cleaning agents. Further, their chemical composition can have adverse effects on seals & gaskets not designed for them or built-up with deposits from the dino oil.
The oil your using is good, as is the filter, though the oil temp is a bit high for dino and the reason Corvettes went to synthetic, as long as you change it regularly, it should be ok to continue to use it (I used 10/40 winter and 20/50 summer in my 85 Supra and had 333k miles when I sold it, engine was still super clean inside).
You could consider using either 20/40 or 10/30 to reduce the amount of viscosity builders needed and available for burn-off and deposits in the engine.
Suggest looking at your coolant system and try and get the coolant temps down (R&R anti-freeze and flush if older than 2 yrs, clean radiator fins and A/C condensor if so equiped, debris between A/C condensor and radiator, fan operation, etc).
Old Oct 11, 2007 | 06:33 PM
CFI-EFI's Avatar
CFI-EFI
WHAT???
Down from "Water temp running 160-180."??? Early in your post, you agreed with me that the coolant was too cool. Why the 180° U turn from one end of the post to the other?
RACE ON!!!
Old Oct 11, 2007 | 06:40 PM
larryfs's Avatar
larryfs
230 oil temp. oh my, that motor is trashed. you must sell it to me immediately for $1000
Old Oct 11, 2007 | 06:47 PM
JackDidley's Avatar
JackDidley
Old Oct 11, 2007 | 11:14 PM
theadmiral94
Default my oops
Originally Posted by CFI-EFI
WHAT???
RACE ON!!!
CFI-EFI,
Your right, I somehow thought I read his water temp was at 210 (it was his oil temp before it climbed).
Please excuse the error and disregard the suggestion of getting the coolant temp down...
Thanks CFI-EFI for catching my error...
Old Oct 12, 2007 | 12:02 AM
TenSecondZ's Avatar
TenSecondZ
20w50 is way too thick for that engine unless it is seriously wornout and eats a quart every 500 miles.
You will decrease your oil temps 10-20 degrees by using a thinner oil.
if you want to use something thicker than a 30 weight (a good option would be maxlife) Use any Diesel oil 15w40 - A more robust oil than the 20w50 and will run cooler
Old Oct 12, 2007 | 12:10 AM
carolinamountains's Avatar
carolinamountains
in my 85 manual, I believe it states the oil temp warning comes on at 300 degrees, just a thought
Old Oct 12, 2007 | 02:29 PM
CFI-EFI's Avatar
CFI-EFI
CFI-EFI,
COOL!!! (pun intended)
RACE ON!!!
To High Oil Temp - Help ASAP
