Longtubes and no cats/resonator..That Corsa will absolutely shriek.
I ran 94 with a Corsa, stock manifolds, and no cats for a short time and it was WAY too loud. I hated it. I put shorties and cats on and like it much, much better.
When I bought the car it had stock manifolds and exhaust with no cats on it. I put the Corsa on and it was so loud I could not stand it so I bought some cats off Ebay. That gave it a very nice sound. I added the shorties not long after but they did not change the sound much.
My LT4 has Corsa catback system, with stock manifolds and cats.
I would like just a tad more noise, without ruining all the cruise comfort
Should i gut/remove the resonator, or delete the cats..
Can you buy some cat delete pipes for a LT car?
Youve got to listen to my Corsa set up in my signature. There is no resonance at all and you can still here a pasenger talk to you inside cabin. Dont get me wrong you can here the lope though. That I like. My set up: EM headers into x pipe then straight pipes into Corsa Mufflers. No cats or resonator! Mild cam 215/224 110LSA Thers another guy on the forum has a very similar sound to his car the only difference was he has Hot cam wich isnt as lopey as mine but he did remove his cats. I believe if you go with headers, no cats you will have your desired sound.
