ZZ4 Camshaft
Old Oct 11, 2007 | 05:55 PM
jam019's Avatar
jam019
Default ZZ4 Camshaft
Has any one used the GM Performance Cam ZZ4,if so how does the computer react to it and how does the idle sound.
Old Oct 11, 2007 | 06:44 PM
JackDidley's Avatar
JackDidley
I have been using a ZZ4 for about 40k miles. Pretty tame. Not real racey sounding. Youn do need a chip tune to take advantage of it. They say you can get by with the stock chip, but I thought mine ran pretty crappy with it.
Old Oct 11, 2007 | 07:02 PM
hexane's Avatar
hexane
My Lunatic cam has very similar specs to the ZZ4 cam. Dart iron heads, Miniram, 323 rwhp, 300ish ft-lbs of torque. It has a stockish idle to it, but you will hear it lope slightly if the idle gets below 800 rpms and/or if I change my timing so I can run cheap gas. Kinda cool sounding. You should be able to run a stock tune without any problems.
Old Oct 11, 2007 | 07:16 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Fill out your profile. People are answering your question without knowing what year car you have.
Old Nov 19, 2007 | 03:58 PM
Calderone's Avatar
Calderone
i have a 1987 L98 Z52 vette
i would love to read more experiences of ZZ4 cams on L98s
Old Nov 19, 2007 | 04:54 PM
dan0617's Avatar
dan0617
IMO, if you are going to go through the work and money of changing a cam, you should go a little bigger than a ZZ4.
Old Nov 19, 2007 | 05:56 PM
Curveit's Avatar
Curveit
That cam IMHO, has too much ex duration, unless maybe you're running a completely stock exhaust system. Most all the GM factory cams are pretty "slow acting" cams too; more overall duration for the amount at .050". An after market cam like Comp Cams will have more bottom-mid range power, and idle better. They will have smaller overall duration numbers for the same .050" numbers. Keep the LSA at 112* or higher, to be more computor friendly.
Old Nov 19, 2007 | 09:37 PM
pr0zac's Avatar
pr0zac
i put a near stock sized ligenfelter cam in my vette when i blew the motor but i kicked myself in the but because now that i have gone through it all over again because the first time didn't hardly show a gain at all and the big cam leaves a much bigger smile on my face..
Old Mar 17, 2008 | 08:14 AM
Calderone's Avatar
Calderone
My ZZ4 Cam is in ! can't wait to test it ...i dont know which would be the real difference with the stock one because my old L98 was really tired when i rebuild it PLUS i added hypereutectic flat tops and ZZ4 Springs ....so im pretty sure i will notice a difference with the old setup of my L98...
Any comments from who currently have the ZZ4 cam on their setups ?
i would love to hear more while im finishing the rebuild ...
What's the main difference in behaivor compared to the stock one ?
Old Mar 17, 2008 | 08:57 AM
rodj's Avatar
rodj
While being in total agreement ,I consider it a good investment for the budget people at the $70 -$100 going rate.
With the GM ZZ4 springs say $130 tops for a cam factory matched to the L98 alum heads.
Ran one for 3 years in my 100K 350.Nice lope , excellent drivibility with stock chip and great performance.
12.9 with modded TPI and headers,no cat ,A4 , 3.07 rear.
1.7X 60ft times on DR's.
After finally getting around to dataloging just prior to replacing with 383 found stock chip has too much advance for cam;WOT.
Slight knock counts under heavy load, WOT which was pulling timing out.Also the idle speed needs lifting from the stock 550 rpm.The cam won't idle down that low so with stock programming it tends to hunt up and down .
Nothing you cant live with but easily programmed out.
If you have no $$$ and need to replace a stock cam , highly recommend.
Old Mar 17, 2008 | 09:01 AM
Calderone's Avatar
Calderone
Rod ! how are you !
so...it was a good move ?
should i do something to my chip ?
thanks !
Old Mar 17, 2008 | 09:29 AM
JackDidley's Avatar
JackDidley
At first I wished I had gone with a bigger cam, but now I feel the ZZ4 is exactly what I wanted. The cam seems to go well with the intake and heads I used. Datalog numbers tell me I am getting the most out of it. The et numbers back that up. With the price of ga$, a bigger cam would just have me buying more and more gas and I have other things to spend my $$$ on.
Old Mar 17, 2008 | 09:36 AM
Calderone's Avatar
Calderone
Gas its no cheap !!
Here we deal with the same
Hey Spank but ,what differences you noticed comparing ZZ4 V/S Stock ?
Old Mar 17, 2008 | 11:03 AM
JackDidley's Avatar
JackDidley
Can't say about just the cam by itself. I did cam/heads/intake.
Old Mar 17, 2008 | 11:53 AM
Calderone's Avatar
Calderone
I wont be able to tell .....
because i added hyper flat top pistons too
so i wont be feeling just the cam
Old Mar 17, 2008 | 12:19 PM
Curveit's Avatar
Curveit
Just a thought... if you're useing stock rocker arms, you might consider putting 1.6 on the intakes only. This would close up the the Intake to Exhaust ratio a bit, especially with the EX porting you've already done. Wouldn't be very costly either. I don't know if I'd do it if I had expensive Roller rockers already, but it should be worth some extra power. Maybe "down the road" you could try it.
Old Mar 17, 2008 | 12:41 PM
Calderone's Avatar
Calderone
I thought about RR's but i discarded the idea ...because of my zz4 springs ...i bought stock zz4 1.5 new rocker arms .-
i haven't done any porting to anything.-
maybe i'll add 1.6 rockers in the future! but i was really close to put 1.6's on it !
To ZZ4 Camshaft
Old Mar 18, 2008 | 04:08 AM
rodj's Avatar
rodj
I was always interested in the wide int /exh differences but figured the factory must have known what they were doing as the ZZ4 heads are the 113 Vette heads.
Mine ran so well I gave up thinking about it
To all the naysayers;
the GM Fastburn 385 is a 350 ZZ4 short block ( with same ZZ4 cam )
and the fastburn heads making 385 Hp so the cam is not that BAD
Old Mar 18, 2008 | 08:37 AM
Calderone's Avatar
Calderone
wow...what's the difference between the Fastburn and the ZZ4 ?
Old Mar 18, 2008 | 12:51 PM
Curveit's Avatar
Curveit
I think it was to help with the restrictive exhaust systems most cars have stock. I didn't say it wouldn't work though, I just think it would work a little better with 1.6 on the intakes. And the price is sure nice too.
Calderone... Sorry about the porting thing. Cusinartvette is working with Vortecs also, and I got the two mixed together.
