ZZ4 Camshaft
Old Mar 18, 2008 | 11:07 PM
Calderone's Avatar
Calderone
what's the difference between the Fastburn and the ZZ4 ?
Old Mar 19, 2008 | 12:54 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
It would be the heads.Fastburn are the newer techno heads over the older ZZ4 heads,which were basically stock design 88-91 Corvette D port heads.
Dont forget,the engines sold in the catalogs are based on carb numbers,not TPI or efi.With TPI or non carb,you wont make anywhere near the HP claims in the catalogs,even if ya use the same heads and cam.
Old Mar 19, 2008 | 12:57 AM
Calderone's Avatar
Calderone
i see,why TPI makes such lower numbers then ?
Old Mar 19, 2008 | 03:05 AM
rodj's Avatar
rodj
Granted but but still usefull as a comparison of what the cam is good for.
With TPI you could be down 20% on carb Hp but undoubtably up in torque
Still maintain excellent bang for the $$ if you need to replace a cam in a stockish engine.
Old Mar 19, 2008 | 08:53 AM
Calderone's Avatar
Calderone
thanks rod!
i think i prefer the torque over the hp
that's what most of use no normal street driving and it gives you good response
