4+3 tranny
Old Oct 11, 2007 | 07:51 PM
jrandnicole's Avatar
jrandnicole
1st Gear
Default 4+3 tranny
I have an 84 vette with 4+3 manual trans. I am sending my dash out for repair. Of course with out the dash cant get a temp signal to engage overdrive. I need to keep driving my grandmother to church, my only other option is 83 grand prix with 396 big block at 10 mpg down hill. I was wanting to know if anybody knows if / what wires can be jumped at the dash harnesses in order to allow the overdrive to engage when selected. I would like to do it in some way like this so I can still use my overdrive button, but worse case to do it where the overdrive is constantly set to engage, of course in this case I would treat her like a virgin bride.
Thanks for your time
Old Oct 12, 2007 | 02:09 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
This should help:
But the temp sender for the ECM that enables OD does not go through the cluster. Speed does so you'll most likely set a code for VSS, but the OD should work without the cluster and without doing anything to the wiring.
