fuel pump whining
Old Oct 12, 2007 | 12:00 AM
carolinamountains's Avatar
carolinamountains
Default fuel pump whining
My 85 L98 has a whining noise coming from the fuel pump, never done it before. it is not real high of a pitch and not loud, just enough to here it, constant at all speeds. no performance issues just the noise, dont know if it is a big deal or not, or the beginning of something. the outside air temp recently dropped. about 42 degrees when this started, dont know if air tem has any bearing or not. any opinions from the people who know?
Thanks, Mike
Old Oct 12, 2007 | 10:10 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Original pump?
Mike - is this the original fuel pump? How many miles does it have on it? If anything over 75000 miles, I would suggest that you change it out as soon as possible before it leaves you in a lurch without notice.
Old Oct 12, 2007 | 10:24 AM
Buddy2003's Avatar
Buddy2003
FWIW, I dont' remember any whining before mine died but It died at 72K on my 96.
Old Oct 12, 2007 | 12:29 PM
carolinamountains
she's got 56000 miles on her I dont know if pump is original or not, probably is I guess. I replaced the filter this morning, same thing. It is the same sound that it makes when the ignition is first turned on. (comes on 2 sec then off). when the car is started, it is just a constant, I can here it while inside the car. I am guessing I should probably replace the pump before it leaves me hanging somewhere.
Thanks for your help
Old Oct 12, 2007 | 09:26 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
I noticed the same thing on my other GM cars before the pump died. Since my fuel level gauge doesn,t work and the Vette has 90k on it, I'll change both while in storage for winter.
Old Oct 12, 2007 | 10:14 PM
bigwave71's Avatar
bigwave71
thats definatly your fuel pump if it does the whinning when you turn the ignition on. change it tommorrow.
Old Oct 12, 2007 | 11:32 PM
carolinamountains
thanks guys for all the help, I will have to order me a pump, probably get it sometime next week, will keep ya posted.
Old Oct 14, 2007 | 05:27 PM
carolinamountains
Default fixed the problem
Replaced the fuel pump and sock today. problem is fixed, also, guess I did have a slight performance issue before. The motor is alot more responsive and smoother. It cost me about 85 dollars and 45 minutes.
Thanks for all the help guys
Mike
To fuel pump whining
