Brake light switch
Old Oct 12, 2007 | 09:57 AM
exp_forum's Avatar
exp_forum
Default Brake light switch
While replacing the brake booster, I inadvertantly pushed the brake light switch plunger in too far and now the brake lights won't go off. Is there any way to pull the plunger back out so I can re-adjust it or do I need to buy a new switch? If so, how? I tried pulling it out with needle nose pliers but didn't want to break it.
Old Oct 12, 2007 | 12:31 PM
jfb's Avatar
jfb
You already broke the switch. Buy a new one!
Old Oct 12, 2007 | 04:08 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
You can pull it back out, I did the same thing.
Old Oct 12, 2007 | 04:16 PM
exp_forum's Avatar
exp_forum
How did you pull it back out?
Old Oct 12, 2007 | 04:25 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
There is a clip on the backside of the plate, just pull it off or do what I did and just pull it out.
What year?
Old Oct 12, 2007 | 04:29 PM
exp_forum's Avatar
exp_forum
What year?
1994. Not seeing the clip. Just pull with needle nose?
Old Oct 12, 2007 | 04:40 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
yes
Old Oct 12, 2007 | 05:03 PM
exp_forum's Avatar
exp_forum
Thanks Randy93!!! Figured it out. The whole switch moves out... not just the plunger.
To Brake light switch
