map sensor
Old Oct 16, 2007 | 08:07 PM
BTTB's Avatar
BTTB
Default map sensor
anyone know anything about map sensor--ALPHA-N
Old Oct 17, 2007 | 11:00 AM
Matt Cramer's Avatar
Matt Cramer
Alpha-N means running with the throttle position sensor and RPM only, without using a MAP or MAF sensor.
Old Oct 17, 2007 | 11:39 AM
BTTB's Avatar
BTTB
What type of system would the alpha-n come into play.
Old Oct 18, 2007 | 12:09 PM
Matt Cramer
I'm not sure if you can reprogram a GM ECM to do this, but most aftermarket tuneable ECMs can be set to run like this.
To map sensor
