Speaker buzzing, what to do?
Old Oct 18, 2007 | 12:21 PM
steve mulherin's Avatar
steve mulherin
Default Speaker buzzing, what to do?
I posted this under the audio catagory and received no response. So, I'll try here. I ahve a '94 with the Boze stock radio / cd. The right front speaker began buzzing above a certain volume. Cna I fix it? If I need to replace it what should I buy? Is the R&R difficult.
Old Oct 18, 2007 | 12:30 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
throw it ALL away.
buy any single din head unit you want for the front (preferably one that plays Mp3s and has a front Aux input jack) $100+ , then a dash install kit and wiring harness ($15 and $10). For speakers, get some 6x9's for the rear and some 6" (I think is the size) for the doors OR for better sound, some 4x6's for the dash. Goto home depot and get a spool of cheap speaker wire and you are set.
Old Oct 18, 2007 | 03:34 PM
Cutter1's Avatar
Cutter1
Most likely the amp for speaker is going i found local electronics shop fixed it for 25 dollars
Old Nov 12, 2007 | 12:09 PM
pcolt94's Avatar
pcolt94
Steve, FYI – Use Bose and you will get a larger response.
Check this thread. I have a lot of info in it of which I have performed myself and with the aid of other links to get me started. Don’t forget to check the first 3 links in my first post. Hope some of this will be of assistance, good luck.
http://forums.corvetteforum.com/show...highlight=bose
Old Apr 9, 2015 | 02:06 AM
lectroglide's Avatar
lectroglide
I had to replace the speaker amp in the drivers door now everythings good thanx to someone here on the forum
Old Apr 9, 2015 | 12:56 PM
HAD2HAV2's Avatar
HAD2HAV2
Steve. Consider yourself fortunate that you own one of the later year Bose radio units. The earlier units, like I had in my 88, were next to impossible to replace the front door speaker amps because one had to rip the guts out of the door to pull the speaker box out.
JIJoe. I ran no speaker wires when I threw away my Bose system (I keep it in the garage for sentimental reasons). I used the Bose speaker wires. I just cut the connectors off and directly wired them to my new 6x9’s in the rear and 4 inch in the door.
To Speaker buzzing, what to do?
