NEW guy-L98
well i will have lots of questions i will ask as i move along, first off i'll tell you about the car..
1985 Chevrolet Corvette l98 114,000mi. $3,900
and crappy pic
i get it next friday
first GM car , been a mustang guy before this so im not new to modding, just to this particular engine
first site i looked at was MAmotorworks saw a few things i wanted to get but reasearched alot here and alot, say its pointless.But i wanna double check with the guys one here who have done this
mods to think about getting
(1)exhaust:buying from GIJOE hopefully
(2a)GEARS:need help i think with the low rpms on this motor i should go with a 3.27 through 3.47 set, but of course having a bunch of mustangs im partial to 4.10s
(2b)airfoil:i mean its only 24.99 on Mid america
(3)accel base and runners: heard not much of a point without heads or cams
(4)CAMS:well since the car will b fairly stock not sure which to go with, i've never been good with cams
(5)100shot possibly.
numbers are in the order i will get them
i am very open to opinions but nothing drastic as u can see i have a short mod list i will eventually go with H/C/I path later on so no advice on that yet and wont care to change the cam when i have to so im looking for the best cam as of listed mods
IM aware of other mods, but i would like ppl who have them to suggest, or decline any im planning of mods i listed
thanks and pleas ehelp me learn
Enjoy your corvette. I used to be ford before 1980. I switched to chevy in 1980. One of the best decisions I ever made.
Oh yea, pitch the mid america catalog. They are overpriced.
http://temp.corvetteforum.net/c4/vader86/
all these mods will b put in over a bit of time, i dont rush things
(2a)GEARS:need help i think with the low rpms on this motor i should go with a 3.27 through 3.47 set - either of these is fine for a L98 but wouldn't go there right away
(2b)airfoil:i mean its only 24.99 on Mid america - skip it
(3)accel base and runners: - they will be worth about 10-15chp
(4)CAMS:well since the car will b fairly stock not sure which to go with - the '85 L98 has a flat-tappet cam so you will need some good RRs to boost the cam effect. TPIS has some flat-tappet cams for L98.
(5)100shot possibly. - don't care for juice personally
I would also include:
-cut lid with K&N: worth 10chp
-160deg T-stat & fan swithch: worth 10chp
-Trans-Go shift kit
You can benefit well from a nice set of hi-flow heads, usually worth 25-30chp.
Enjoy your new Vette...
However, you might want to ditch the nitrous idea for now if you want power all the time. A good set of aluminum heads and headers will go a long way. Add a cam to that and you've got 300+RWHP easy.
power all the time isnt a big issue, im happy with at lest a mid 13 on motor and whatever else i can get with nitro
how/ where can i find me some 89 heads? used/new/fully assembled-whatever doesnt really matter
The compression on the large '85 iron smog heads is 76 cc and about 9:1. The '89 AL heads have around 56cc and the compression with your flat top pistons would push 11:1 on today's 93 gas.
Might be a bit too much. Just to give you an idea
3 angled my iron heads
TPIS long tube header
450/472 214/224 cam
Ported the stock base and plenum
Accel runners
On a 4 wheel drive dyno which has a larger power loss than a 2 wheel drive dyne per the dyno manufacturer. The power conversion to the crank was 28% with an automatic and 25% with manual
The numbers were 224 RWHP = 311 crank and 289 RWT = 401 crank
These are real world numbers. The car will run a tick under 5 second 0-60. I never took it to the track after the mods, but when stock it ran low 14s.
The L98 is all about torque and at 4500 RPM the game is all over for HP
Give it 6 months before you start doing anything, at least. You need to get to know the car and figure out what you like and dislike about it.
Best money you can spend right now is on a Helm Shop Manual, helminc.com.
i can get c5's for 12-15k with 70-90k miles
After that you can work on the intake side. Lots of options.
Just up grade my exhaust with a Corsa from stock and THAT was noticible improvement.
