NEW guy-L98
In Fl. I'll wager that the trans has already had a rebuild - at Least one. Assuming an automatic here... The Dana 36 rear is going to be worn pretty badly also - it'll be not just Gears but a complete diff rebuild. A taller ratio will help though - and will also push the rpm's up/gas mileage down on the highway.
The L-98 is a low rpm torquer - the party is over at about 4500 (it ain't no Ford motor..). Be careful with Too much gear in it, you Want to hold the tach down where the good torque numbers are.
Drive it for awhile before tearing into it - Then decide what it "needs" to make you happy. Like has already been said - you'll probably be busy enough fixing Other stuff anyhow
Give it 6 months before you start doing anything, at least. You need to get to know the car and figure out what you like and dislike about it.
Best money you can spend right now is on a Helm Shop Manual, helminc.com.
It's your money, my car had 16K on it when I got it and I've had it for 5 years and I'm always fixing something minor, it never ends !
Here are the results you can expect on a stock L98 from various engine modifications. This information is from VADER's website which has a lot of pretty good stuff on it:
Corvette L98 Modifications & Expected Results:
(Track Times from a 1989 L98 car)
Bone Stock -> 13.87@98.60 MPH (60 degs , 2.0 60')
With Crank Pulley -> 13.74@99.56 MPH (60 degs , 2.0 60')
With drag radial tires, TB Bypass , K&N , Air Foil , Cut Lid
-> 13.34@102.20 MPH (40 degs,1.85 60' )
With Air Pump Elimination , 12" GM Convertor , Ported MAF ,160 stat
-> 13.16@102.04 (65 degs , 1.76 60')
With TPIS catback ->12.85 @104.90 (45 degs , 1.74 60')
With Accel lower Manifold ->12.96 @105.18 (45 degs, 1.79 60')
With AS&M runners ->12.81 @107.09 (65 degs, 1.73 60')
With Hooker headers he made 271rwhp and 345rwtq.
Good luck! AND Welcome to the Forum
only do gears if it's an auto. Gears on the 4 speed are pointless due to the low peak hp on the tpi.
Years ago, people took out the chock plate for better flow for the same reason. I say, for the price, get the air foil. Yes, I did buy one and although I don't have a dyno, I think it does help.
