antenna problem
Old Oct 20, 2007 | 11:32 AM
Kizmo's Avatar
Kizmo
Default antenna problem
Ok it goes up but it won't go all the way down. It has about six inches still sticking up. I used to be able to push it down but it wont do that any more either. Mast or Motor?
Old Oct 20, 2007 | 12:54 PM
Brimis's Avatar
Brimis
Mast
Old Oct 20, 2007 | 01:13 PM
badabing9's Avatar
badabing9
probably the mast. i woule remove teh motor by dropping out from the fender and resting on a milk crate or similar. get a replacement mast section from "the big auction site". take apart the motor and remove the broken mast ribbon (most likely broken) after removing old grease and any broken fragments. re-lube and install new mast section.
Old Oct 21, 2007 | 12:00 PM
Kizmo's Avatar
Kizmo
Thanks!
To antenna problem
