Since I installed a new Y pipe, and reduced the three doggy cats to one, I think I hear a slight ping during accel. The ping gets detected/corrected by the PCM in in 1/2 sec or so. I don't remember hearing it before. (Maybe I just wasn't listening as hard before)
Does this exhaust change somehow affect the PCMs timing determination?
Changes or mods made on a SD car(727/730) ecm can have effects on the blm (rich/lean). While timing and fueling tables are pre-set in the prom, after changes are made to motor set-up they usually will need to be re-tuned. MAF cars seem to be 'forgiving' when doing some mods.
thanks,
I just noticed that someone had a similar problem caused by a new Bosch 02 sensor. I installed one along with the Y. I am going to switch back to my old 02 and see what happens.
