What's up with this engine??
Old Oct 22, 2007 | 01:24 PM
joseph p's Avatar
joseph p
Default What's up with this engine??
Hi,
I put an '89 Corvette 350 TPI/700R4 into a hotrod, using all the stock sensors, wiring etc.
It has a peculiar "miss" coming out of the left exhaust(only after it warms up). The wiring is new, plugs, cap, coil new. Timing 6 degrees, TPS and IAC set properly. Compression tests good. I'm going to check if the exhaust valve or valves may be too tight, but other than that ...I'm at a loss.
Any suggestions?
Old Oct 22, 2007 | 02:13 PM
CFI-EFI's Avatar
CFI-EFI
According to your post, everything is new and perfect. Does it have a check engine light? Can you check for trouble codes?
RACE ON!!!
Old Oct 22, 2007 | 07:14 PM
joseph p's Avatar
joseph p
It has no check engine light and no codes except for a 43 (knock sensor) which I assume is the result of the engine's miss rather than the cause of it.
Old Oct 22, 2007 | 08:04 PM
JackDidley's Avatar
JackDidley
Did you try and narrow it down to one cylinder ? That should lead you to a, valve, an injector, or a plug/wire.
Old Oct 22, 2007 | 09:39 PM
CFI-EFI's Avatar
CFI-EFI
Does that mean that the hot rod has no check engine light? Or that the CE light wasn't lit? How do you read codes? For my car, the code 43 is set when the ECM receives low voltage on circuit 485, from the ESC module for longer than 4 seconds. The voltage from ESC drops when the the ESC receives a signal from the knock sensor. The knock sensor can be triggered by "sounds" other than knock, known as "false knock". I would expect a custom engine installation might be even more prone to false knock than the factory installation. When the voltage from the ESC drops below 6 volts, the ECM retards the timing to stop the detonation. When 4 seconds of retarded timing doesn't stop the knock, the the ECM sets the code, and keeps the timing retarded as a fail safe. Obviously, retarding the timing won't stop false knock (like something banging against an exhaust pipe) and the ESC will continue to receive the knock sensor signals. A miss should not cause a code 43 to set, however, knock counts shouldn't cause a miss, either. Knock counts will, of course, cause the timing to be retarded which will reduce the power and make it sluggish. One way or the other the cause of the code 43 needs to be taken care of.
RACE ON!!!
Old Oct 22, 2007 | 11:12 PM
joseph p's Avatar
joseph p
CFI-EFI, you sound on track. The car does not have a CE light and I guess I don't understand the Code 43 as well as you do. The engine miss (actually sounds like it's puffing air out the left exhaust pipe) happens only after the engine has warmed up to the point where the idle drops. It is not there for the first 3 minutes or so when the engine is cold. Does that help explain my problem clearer? Help!
Old Oct 22, 2007 | 11:18 PM
_twisted_'s Avatar
_twisted_
It sounds like it is fine in open loop, then when warm(closed) is the issue.
Your going to have to do some data logging
Old Oct 23, 2007 | 12:30 AM
joseph p's Avatar
joseph p
According to the wiring harness manufacturer, I changed the engine from MAF to speed sensor and changed to a later ECU...could the fact that I didn't change the knock sensor cause this?
Old Oct 23, 2007 | 12:55 PM
joseph p's Avatar
joseph p
Ttt
Old Oct 23, 2007 | 08:01 PM
CFI-EFI's Avatar
CFI-EFI
If the car isn't equipped with a "Check Engine" light, where does the code 43 information come from?
So you started with a 1985 - 1989 engine? You ditched the MAF and added a MAP? What year ECM are you using? Do you even have the ESC?
I am 99.40% sure the ESC/knock sensor isn't causing the miss, but the code 43, wherever it came from, indicates a problem that should be fixed. It is easier to trouble shoot and isolate a problem, where there aren't OTHER problems complicating the issue and diagnostic test results.
RACE ON!!!
Old Oct 23, 2007 | 08:16 PM
joseph p's Avatar
joseph p
It does not have a check engine light but it does have a simple red light on the Telervek unit where all the wires connect. Grounding A and B on the ADL produced the code 43.
This is a common practice when putting '89 and older TPI's into rods..to change to speed density so you have a clean air intake without the MAP sensor between it and the filter.
Old Oct 23, 2007 | 08:23 PM
joseph p's Avatar
joseph p
Excuse me...I'm using the '90-'92 MAP system and replacing the MAF system. I'm using a '90-'92 ECU with stock prom..
Old Oct 24, 2007 | 06:45 AM
rons85's Avatar
rons85
That sort of "single cylinder", presumably, miss or oddness would have me looking for an exhaust leak (header flange maybe), a leak on the Intake side (vacuum), a bad or iffy injector and Last an ignition problem (plug, wire, cap, etc.).
Have you checked header temperatures? Is there a "cold" cylinder? Checked (with a timing light) for an electrical miss at a particular cylinder? How about using a 'noid light to watch the injectors on that bank for an intermittent no-fire...
Since you say the compression is fine I would stop worrying about a Valve problem - although a too tight adjustment could still be the cause. Did you do the compression check Cold, or warmed up?
BTW - which side (or both) is the O2 sensor in? Same side as the miss?
Is there an ALDL connector wired in to this harness - can you hook a scan tool or datalogger up? If not, it's easy enough to add - only a ground and serial data line that are really neecessary for a scan tool to show what's happening.
Old Oct 24, 2007 | 03:37 PM
joseph p's Avatar
joseph p
No exhaust or intake leak...header temps were checked and are all pretty much the same...(brand new)o2 sensor is on the same side...there is no ALDL sensor.
I cleared the codes yesterday and unhooked the knock sensor. The symptom was still ther whoever much less noticeable.
Old Oct 24, 2007 | 03:40 PM
cv67's Avatar
cv67
St. Jude Donor '05
do you have the 2 into 1 into 2 exhaust on there still
Old Oct 24, 2007 | 04:24 PM
joseph p's Avatar
joseph p
True dual exhaust with chambered pipes.
Old Oct 25, 2007 | 12:58 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I would ohm out your injectors. When I got true duals on my '90, I noticed a miss that I did not feel before. After a lot of searching , I found it was the injectors.
To What's up with this engine??
Old Oct 28, 2007 | 10:28 AM
joseph p's Avatar
joseph p
How would I do that?
Old Oct 28, 2007 | 10:43 AM
joseph p's Avatar
joseph p
Incidently, I no longer have the code 43 readout since the wiring harness people told me to change the knock sensor to a '90-'92 KS. No codes, noise is quieter, but still there, only after going into "closed loop." It runs and sounds fine when cold.
Old Oct 28, 2007 | 11:06 AM
FD2BLK's Avatar
FD2BLK
An exhaust leak could only show its ugly head when the motor heats up. I would take a very close look at the exhaust manifolds, use an inspection mirror and flashlight for underneath.
