Best headers?
Old Oct 22, 2007 | 10:12 PM
mechguy79's Avatar
mechguy79
Default Best headers?
Does anyone have a recommendation on good header? I will be doing a complete exhaust on my 1990 L98 car. Stainless? Ceramic coated steel?I have found a couple of headers going for around $550 from Hooker. I also found a complete stainless kit back to the mufflers with X pipe for $1600. Just wondering what everyones personal experience is before I choose. Thanks all
Old Oct 22, 2007 | 10:26 PM
redvette6spd's Avatar
redvette6spd
TPiS here great header no problems been around forever
Old Oct 22, 2007 | 10:30 PM
StealthLT4's Avatar
StealthLT4
Hooker and TPIS are probably the best bang-for-the-buck, but if you're looking for all-out performance, Exotic Muscle is pretty highly regarded around here. Pretty pricey as well.
Old Oct 22, 2007 | 10:55 PM
vader86's Avatar
vader86
Hooker and TPiS, you want ceramic coated for the heat dissipation properties.
Old Oct 23, 2007 | 01:39 AM
mechguy79's Avatar
mechguy79
How many of you have had a problem with the long tubes dragging? That is something I need to avoid. Another thing I have noticed is the 1 3/4" tubes seem to all be 18gauge, and the 1 5/8" are 14 gauge. I am leaning towards the smaller tubes with thicker walls personally as my motor is a stock L98 and I don't have much of a top end anyways. I had these in mind, but the dragging thing is worrying me:
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 23, 2007 | 01:47 AM
tjwong's Avatar
tjwong
Melrose, check them out at www.melroseheaders.com
If you have a LT1 car, they have them as well. Another alternartive is the Exotic Muscle headers which are great as well.
Old Oct 23, 2007 | 03:27 AM
vettin_it's Avatar
vettin_it
Exotic Muscle has a great product. I know for a fact that there is no issues of ground clearance with their headers. they are completely flush with the floor board. lots of time and experience put into their products
Old Oct 23, 2007 | 07:12 AM
JLeatherman's Avatar
JLeatherman
I've got coated Hedman elites. Fitment is good, and they're pretty cheap.
The Melrose system, headers to mufflers all stainless, is a fantastic product though. If I could afford it it would be on my car. If you can afford to drop the $1600 I'd say go for it.
Old Oct 23, 2007 | 08:21 AM
mechguy79's Avatar
mechguy79
Do they scrub at all? I was leaning that way. I don't have $1600 to spend. I am going to be changing the whole trans and my exhaust is shot, so I figured I would do the exhaust at the same time. Cost effective (affective?) is the goal for me. I can't have something that hangs too low is all.
Old Oct 23, 2007 | 08:42 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Hedman Elite www.summitracing.com
Old Oct 23, 2007 | 11:08 AM
vader86's Avatar
vader86
I have hit the header collectors on speed bumps if i go to fast, but otherwise nothing.
Old Oct 23, 2007 | 11:51 AM
anesthes's Avatar
anesthes
That scares me to death... Aluminum heads are nice for weight saving and heat, but its all too easy to pull the threads out..
-- Joe
Old Oct 23, 2007 | 08:46 PM
redvette6spd
-- Joe
My vette is lowered on all 4 corners have never rubbed or scraped my headers. All brands mentioned above will not scrape one more thing I have never heard mention ever of someone bottoming out a vette and pulling out header bolts.
But if you happen to live in Hazard county and you refer to your vette as the General then I will retract my statements.
Old Oct 23, 2007 | 08:56 PM
mechguy79's Avatar
mechguy79
Well.....the car is in Alabama.
Old Oct 25, 2007 | 08:38 AM
mechguy79's Avatar
mechguy79
Ok, I read something on Vadervette's page that concerns me. He REALLY doesn't like the hedman headers at all. I was actually leaning toward a set of hedman elites as they are a bit thicker walled than the hookers. I am on a budget. He never did mention what his beef was and some of the folks that responded above seem to like them. Just wondering if anyone has had any particular issues with them. Also, I am going to keep this car smog legal and my vette has the three cat set-up. Anyone know if it's cool to go to a single cat? Texas is an inspection state and that's probably where I am going to end up after here, just so you all know. Thanks again
Old Oct 25, 2007 | 02:58 PM
-WhItE_NoIsE-'s Avatar
-WhItE_NoIsE-
I want TPIS i've heard they are the best go to tpis.com they got everything there!
Old Oct 25, 2007 | 03:45 PM
aklim's Avatar
aklim
I do like my TPIS headers
To Best headers?
Old Oct 25, 2007 | 04:02 PM
Slalom4me's Avatar
Slalom4me
If SS construction, 1-5/8 primaries and slip-fit collectors (no flanges to
drag) sounds interesting, then consider headers by Stainless Works.
They install well and offer good ground clearance.
Old Oct 25, 2007 | 05:36 PM
redvette6spd
TPiS, Stainless Works, Melrose, Exotic Mussel, all have heavy flanges that don't warp or bend due to heat or over tightening "they don't leek" Headmans are cheep flimsy. I cant answer about your cats we have no testing here so I'm not running any.
Old Oct 25, 2007 | 06:07 PM
vader86's Avatar
vader86
My problem is the quality and fitment of the regular hedmans, not the elites. I've never messed with the elites so I have no real opinion of them either way.
